Author Topic: Torsional vibration damper with decoupled pulley..  (Read 2923 times)
platty
  • Cambridge
    • BMW 530d Sport
« on: 25 June 2010, 08:46:04 »
Hello, further to The Boy supplying me with the engine manual last night, needless to say I have now found a name for the stupid piece of engine that has fallen to pieces on (and off) my car.
The trouble is, I am struggling to remove the remainder of it - has anyone had the front pulley off a TD before? Please see (upside down) picture below:
Do I need to remove the main crank bolt and take the whole assembly, including big steel backing plate, off?
Any help greatly apreciated as it is making me sweat a bit at the minute!
Re: Torsional vibration damper with decoupled pulley..
« Reply #1 on: 25 June 2010, 08:50:57 »
Centre bolt can stay where it is. Give the centre a spray of plusgas, let it soak then gently prise it off with screwdrivers opposite each other ;)
platty
  • Cambridge
    • BMW 530d Sport
« Reply #2 on: 25 June 2010, 08:59:40 »
Thanks Pete. If the centre section won't slide out easily, will it come out as a full assembly so I can get it on the bench and thrash it?
I will have to find the Plusgas tonight then!
« Reply #3 on: 25 June 2010, 09:28:24 »
You'll need something to hold the crank still which wont be easy due to the recess of the pully. I made this one from an old spanner ::)
« Reply #4 on: 25 June 2010, 09:35:17 »
Can't remember how I got it off, but I have one here.  Pretty certain it comes off similar to all other crank pulleys....
platty
  • Cambridge
    • BMW 530d Sport
« Reply #5 on: 25 June 2010, 09:57:09 »
Is this something you would be willing to part with for a price?
I think it should just "slide off", its probably the 202k miles of it being attached that is stopping it  ;D
2woody
  • Northumberland
« Reply #6 on: 25 June 2010, 13:11:14 »
I always chop off the centre bolt. Compared to the price of a new bolt, it's not really worth faffing about.
hoofing it
« Reply #7 on: 25 June 2010, 13:37:01 »
If I mind right the smaller bolt holes (m6) are the extractor bolt holes.
You just screw them in and it in turn pushes the pulley off. you only turn each a couple of turns at a time then swap over
platty
  • Cambridge
    • BMW 530d Sport
« Reply #8 on: 25 June 2010, 13:46:41 »
I thought that they may have been but at least one of them seems to be a locating peg - either that or there is something stuck in the hole!
« Reply #9 on: 25 June 2010, 13:53:45 »
If your luck is anything like mine.. the remains of the bolt the last person used to try and back the pulley off ..  ;D
platty
  • Cambridge
    • BMW 530d Sport
« Reply #10 on: 28 June 2010, 09:22:11 »
Right, turns out that the smaller holes go onto locating pegs so they were a no go. With rads still in place there is no chance of getting any decent leverage and there is no gap at the rear to get any purchase with screwdrivers.
So... water pump pulley off, special bar made up to hold crank in position and undo big tight nut - leaves me with this:
After some fairly heavy persuasion - they finally parted company, leaving me with this:
Just need to find a new one now... I shall keep you posted  :y
