Author Topic: Condenser parts No  (Read 1388 times)
Condenser parts No
« on: 03 July 2010, 18:11:08 »
Can anyone tell me the part No for the O rings from the condenser to the aircon pipe work.
TIA :y
Re: Condenser parts No
« Reply #1 on: 03 July 2010, 18:15:22 »
Copy of PM received from AndyC.
hi Rob
As far as i can make out it should be 2 x 90381758 but EPC is as clear as mud.
These seals are for the two pipe clamp that has the bolt through the middle  and are listed as 9.3 x 2.4
Cheers
Andy
Assistant Parts Manager, Drive Vauxhall, Bury St Edmunds, Suffolk. 01284 777254.
« Reply #2 on: 03 July 2010, 18:48:58 »
Brilliant, Cheers Rob :y
« Reply #3 on: 03 July 2010, 18:50:16 »
Usually a 2-day wait Pete. Not an "on the shelf" item
« Reply #4 on: 03 July 2010, 18:51:09 »
Yeah thats normally the way. Its a job for next weekend :y
« Reply #5 on: 03 July 2010, 18:52:21 »
Where did you get the condenser/drier :question
« Reply #6 on: 03 July 2010, 18:53:43 »
Its off the Elite i'm breaking, thought I would take a chance as it looks in good nic ;)
« Reply #7 on: 03 July 2010, 18:56:20 »
Are you gonna get a nitro/air pressure test on it or just whack it on and hope ;D
« Reply #8 on: 03 July 2010, 18:57:13 »
Whack it on and hope ;D
« Reply #9 on: 03 July 2010, 19:00:03 »
Don`t know how you do it, but instead of releasing the hoses from the autobox cooler pipes I found it easier to undo the single torx bolt at the pipes union block top l/h side of rad
« Reply #10 on: 03 July 2010, 19:02:20 »
I'm taking the rad out anyway. I want to see if I can remove the viscous fan and fit an electric aircon fan instead :)
« Reply #11 on: 03 July 2010, 19:12:33 »
It`s nice when you got a load of spare bits to play around with. Good luck  :y
« Reply #12 on: 03 July 2010, 19:14:35 »
My wife doesn't think so ;D
