Author Topic: found why engine is pinking and lakes power  (Read 2336 times)
same #same#
  • south yorks
  • dont blame me im dyslexic
« on: 05 July 2010, 18:26:56 »
was looking under the car and looked fine but the exhaust rubbers looked a bit strecked, so pushed exhaust up and it moved easy, but could see it move at the flex pipe, so had a look ( snaped)  the wire is the only thing holding it together. so need to get a new one... only been this way a few days idle has been off a bit going up and down just heard ticking sound.. :( :( found new flex £18 so will have to get it a weld it on.
Re: found why engine is pinking and lakes power
« Reply #1 on: 05 July 2010, 20:32:50 »
Does it run on water ::)
same #same#
  • south yorks
« Reply #2 on: 05 July 2010, 21:46:10 »
if it was its not now, ;)
same #same#
  • south yorks
« Reply #3 on: 05 July 2010, 21:49:47 »
just getting ready for transplant, cut old one off clean'd up pipes, flex spring snapped inch off end, so just got to order part and at same time fit new cat, :y
    • 530D M Sport, 330i Coupe
« Reply #4 on: 05 July 2010, 22:13:26 »
Was it rusty? Seen similar on an M 95 model
same #same#
  • south yorks
« Reply #5 on: 05 July 2010, 22:16:46 »
no just a bit sooty, think it just gave up the goat.
« Reply #6 on: 05 July 2010, 22:30:03 »
;D ;D ;)
« Reply #7 on: 05 July 2010, 23:04:28 »
;D ;D ;)
I`ve often wondered if they`re one and the same (same).  :D Possibly interbred ;D
« Reply #8 on: 06 July 2010, 02:31:23 »
;D ;D ;)
Wonder no more - same (same) Rusty M 95 :) :) :)
Is it ok to run 2 user names? :o :o :-/
« Last Edit: 06 July 2010, 02:32:29 by dbug »
same #same#
  • south yorks
« Reply #9 on: 06 July 2010, 06:21:49 »
i give up, not rusty have no idear what you are on about????
« Reply #10 on: 06 July 2010, 07:18:11 »
panto mode on.
OHHH YES YOU AAAARE.
Panto mode off.
 ;D
« Last Edit: 06 July 2010, 07:19:34 by chrisgixer »
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #11 on: 06 July 2010, 08:51:23 »
Allo - Allo..........
Lakes power & giving up the Goat?
Malapropisms?
& how is Sooty involved?
same #same#
  • south yorks
« Reply #12 on: 06 July 2010, 10:33:53 »
i have no idear what you are all on about im leving this site better off sticking with vxnet,
« Reply #13 on: 06 July 2010, 13:30:17 »
[/highlight]
samesame, i'm really sorry you feel the need to leave the OOF, especially as you appear to have no idea why the other members were being juvenile! There was a member here not so long back with the username Rusty97 (iirc?) and he like your good self, was not too hot on 'hitting the right keys' shall we say? and not getting his message across too clearly at times :-/. Anyway, the guys answering your post believe you are really Rusty97 using another username to disguise your 'real' identity?
Whatever the truth of the matter, I personally feel they have gone OTT and ended up being unintentionally rude?. IMHO, mate, you should 'turn the other cheek' & laugh it off! ;) because life's too short at the end of the day, and besides; vxnet sucks compared to the OOF ;D :y
