Author Topic: 4 Pot leaking oil from sump sensor connector.  (Read 2070 times)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« on: 07 July 2010, 15:15:26 »
just had a look under the car, oil is leaking from the sump sensor at the connection. The plastic connector feels loose in the sump.
Someone please tell me that the bottom half of the sump doesn't have to come off to tighten/seal it, because it looks that way as there are no bolts on the outside  :(
Saving for one! All donations welcome, ask for details.
Re: 4 Pot leaking oil from sump sensor connector.
« Reply #1 on: 07 July 2010, 15:18:12 »
Ok, I wont tell you then.....(but it does)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #2 on: 07 July 2010, 15:26:48 »
break >:(
Any idea how much the gasket costs. I doubt I could afford it ATM or to keep feeding it with oil :'(
Is there no way to seal it from the outside?  :-/
V6Astra F
  • Heidelberg , South Africa
  • 3.2 V6 Powered Kadett
« Reply #3 on: 08 July 2010, 05:15:50 »
Hi
Sorry to say mate , but you cant do it without dropping the sump  :(. I have to do mine aswell in the near future on the V6.
same #same#
  • south yorks
  • dont blame me im dyslexic
« Reply #4 on: 08 July 2010, 06:27:27 »
is it split sump?? or singel,... 2.0L
« Reply #5 on: 08 July 2010, 09:02:35 »
Surely you should know, you have a 2.0  :-/
Back on track yup its sump off, not too bad a job really on 4 pots, just think of it as a very thorough oil change  :)
same #same#
  • south yorks
« Reply #6 on: 08 July 2010, 12:44:58 »
yeah but there is two types of sump split ones are easyer to get off then singal one.
