Author Topic: Alternator Repair/replace?  (Read 1156 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 08 July 2010, 14:01:54 »
Thanks to very quick replies it qappears my alternator in on it's way out due to making a horrid whineing dental drill type noise through the stereo!
Can a v6 be Alt be repaired when this starts or its it a straight replacement jobbie?
Anyone know how much for a new one?
Re: Alternator Repair/replace?
« Reply #1 on: 08 July 2010, 14:07:39 »
Hmmm....not convinced....is the battery charging ok?
Any sign of the charge light being on?
Any bolt on bits or additions to the car?
Are the 0V connections all ok?
mikeh
  • London
    • 1999 V6 2.5 petrol MFL
« Reply #2 on: 08 July 2010, 14:09:11 »
Had my 2.5 V6 alternator bearings replaced by Lucas in 2003 for £100.00. At the time it was a lot cheaper than a replacement from a main dealer.
« Reply #3 on: 08 July 2010, 14:11:11 »
This is thread in question, but dubious about reference to interfering with TV's!  :-?
If is an alternator issue, would the problem not also occur when there is high load on it, like heated rear screen or heated seats on?
Edit, helps if include link....
http://www.omegaowners.com/forum/YaBB.pl?num=1278593064
« Last Edit: 08 July 2010, 14:16:41 by tunnie »
« Reply #4 on: 08 July 2010, 14:12:21 »
Kin ell!
100 quid for 12 quids worth of bearings and half an hours work!
mikeh
  • London
« Reply #5 on: 08 July 2010, 14:14:55 »
I was quite happy at the time compared to dealer quote of £500 to supply new and fit.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #6 on: 08 July 2010, 14:41:06 »
Well to expand it appears to be charging ok as far as I can tell, the battery was replaced recently at the end of it's 2 year warranty and when the factor tested it he said it was defo the battery.
TBH I am advised to check the earths and have not done so as yet, so may be jumping the gun a bit.
« Reply #7 on: 08 July 2010, 15:45:10 »
Lol, semantics I know but......your earth will be a ground spike somewhere and related to your house wiring, your chassis ground or 0V connection will be on your car  :y
