Author Topic: orange emissions light  (Read 1019 times)
dunpullin
  • ayrshire scotland
« on: 08 July 2010, 22:27:43 »
the story so far
changed the timning belt early may
hg replaced with head skim late june
early problem after hg replaced,car started ok but would not rev switch off start again no problems this has now disappeared car running great
emissions light now comes on every time car is started and stays on  where do i start to look please
sometimes at initial start up it sounds as if there is a flat spot or only firing on 3 cylinders
Re: orange emissions light
« Reply #1 on: 08 July 2010, 22:36:18 »
First thing I would do is check the timing is still ok, then check the plug wells for oil/water, & the dis pack rubbers for perishing/cracks. :y
dunpullin
  • ayrshire scotland
« Reply #2 on: 08 July 2010, 22:49:24 »
sorry to be a pain but how do you check the timing can it be done by a complete novice with little more than a few spanners and sockets
i know that at least one of the dis pack rubbers is fubard
will check plug wells early next week at the latest
i'm thinking its not to serious as the car is really running great
thanks for all your help
« Reply #3 on: 08 July 2010, 22:50:40 »
Put your location in your profile .. there might be someone near you with the right kit to read the codes and see why the light is on .. :)
davethediver
  • Blackburn, Lancs.
« Reply #4 on: 09 July 2010, 09:59:45 »
Change this as it could well be the source of the misfire :y
« Last Edit: 09 July 2010, 10:00:20 by davethediver »
P.A. Caron de Beaumarchais
« Reply #5 on: 09 July 2010, 10:03:52 »
how bad is the rubber damaged? this would not help matters...
Drop a PM to Hotel21, he's a bit of a drive away in Fife, but has tech2, and get codes read and see whats going on.
To check timing if you want, look at the crank pully, at the bottom is a lug or gap/recess type thing, this should line up with gap in the back cover when the engine is at top dead centre. (lugs in the cams line up with top cover)
