Author Topic: oil leak  (Read 1857 times)
des
  • stoke-on-trent
oil leak
« on: 09 July 2010, 01:26:03 »
re oil leak tryed non vauk gaket :( tryed gen vauk rocker gasket still got oil leak :( on a 2000 2.0l 16v wot next :(
any help please.
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: oil leak
« Reply #1 on: 09 July 2010, 01:30:04 »
Have you cleaned the breathers properly?
TuBy's new whipping boy.
Re: oil leak
« Reply #2 on: 09 July 2010, 01:35:01 »
As said, plus use black goo in cam cut outs as the guide?
same #same#
  • south yorks
  • dont blame me im dyslexic
Re: oil leak
« Reply #3 on: 09 July 2010, 01:35:11 »
any help please.
wear is it leaking from ish??? or is it the rim??
des
  • stoke-on-trent
Re: oil leak
« Reply #4 on: 09 July 2010, 01:38:16 »
as far as i know yes !!!! did not expect 2 hav the same prob with this car as i had on my 94 car bugger  :( but worse !!!!!!
des
  • stoke-on-trent
Re: oil leak
« Reply #5 on: 09 July 2010, 01:40:55 »
can not see were it is coming from !!!! must be from the back some where !!!
des
  • stoke-on-trent
Re: oil leak
« Reply #6 on: 09 July 2010, 01:42:13 »
If not rocker gasket where :(
same #same#
  • south yorks
Re: oil leak
« Reply #7 on: 09 July 2010, 01:43:34 »
did you check that the rubber is in right like half moons??
des
  • stoke-on-trent
Re: oil leak
« Reply #8 on: 09 July 2010, 01:45:58 »
woz both when i 1st got it  :-[ will double check now with the gen vauk 1 on :)
des
  • stoke-on-trent
Re: oil leak
« Reply #9 on: 09 July 2010, 01:48:26 »
yes m8 checked all that my 1st omega woz a 94 with same prob-but this is worse :(
same #same#
  • south yorks
Re: oil leak
« Reply #10 on: 09 July 2010, 01:53:58 »
also check breather hole as if blocked can blow seal, build up in side the cam cover chamber.
« Last Edit: 09 July 2010, 01:54:45 by Russ76 »
Re: oil leak
« Reply #11 on: 09 July 2010, 07:45:02 »
Only tighten the bolts to the proper torque, don't be tempted to tighten them 'a bit more just in case' :y
des
  • stoke-on-trent
Re: oil leak
« Reply #12 on: 09 July 2010, 20:44:35 »
know wot u mean :) hav done them to the setting's
think it might not be rocker gasket (bugger)
