Author Topic: TD intake manifold cleaning  (Read 1192 times)
SR-71 Blackbird
  • Watford and Nottingham Uni
« on: 11 July 2010, 14:45:52 »
hey guys just wondering how beneficial it is to clean the intake manifold on my TD, was gonna take the egr assembly off and then clean the manifold from the inside using a toilet brush and white spirit, my car smokes alot at night so i thought i would clean the intake as i doubt it would have been done before,
does anybody have any tips or have done it before and could tell me how to avoid problems
Re: TD intake manifold cleaning
« Reply #1 on: 11 July 2010, 14:55:20 »
Its easy to do, just buy 6 new gaskets before you remove the manifold. You'll be suprised at how choked the inlet will be :o
SR-71 Blackbird
« Reply #2 on: 11 July 2010, 15:00:03 »
thanks pete, how much of an improvement does it make, in terms of power, acceleration, mpg or fuel economy, smoothness of engine, reduction of smoke etc
thanks
« Reply #3 on: 11 July 2010, 15:02:42 »
thanks
I can't honestly say as I bought my diesel as a non runner and did all the work before ever driving it.
SR-71 Blackbird
« Reply #4 on: 11 July 2010, 15:08:05 »
ok thanks, i white spirit the way to go? it seems to have cleaned the egr valve pretty good,
PC Techy
  • Bath
« Reply #5 on: 12 July 2010, 09:14:04 »
Did mine during the week. Was surprised how clean it was,just a light misting of oil. Had a bmw 325 tds (same engine) that had a layer of hard crud about 5mm think all around the inlet runners. I've had the egr blanked for a while which helps alot. I also found the manifold gaskets were missing due to a previous numpty owner. Does make a difference after a good clean out.
DUE TO CUT BACKS, THE LIGHT AT THE END OF THE TUNNEL HAS BEEN SWITCHED OFF
