Author Topic: 3.0 V6 Engine cutting out  (Read 1298 times)
greenomegaman
  • Newbury
« on: 12 July 2010, 21:47:55 »
Hello All,
Can anyone give me some pointers on a problem with my 1996 Elite 3.0L please?
115k miles. Engine fully maintained, never previously misfired/stalled and never runs roughly.
These two occurences may not be linked, however....
On a 200 mile round trip last week - all motorway & A-road -  I'm certain I heard a loud knock/thump, with an accompanying momentary judder about 10 minutes into both the outward and return trips. (if it makes any difference, it was quite a warm/hot day)
On the way back I stopped to refuel, and shortly afterwards the engine simply switched off, at motorway speed. I noticed the display screen messaged "AUTOMATIC --------". Unfortunately as the segments have failed I couldn't read the second word.
It turned over normally but no hint of firing, however after allowing 25-30 minutes (awaiting recovery) it started quite normally, and I returned 20 miles or so home.
The next day I went out locally and again it cut out when thoroughly warm, this time when ticking over and once again only fired up once it had cooled a little and/or 25 minutes or so had passed. (No on-screen message this time, and no warning lights).
It looked to me as if the temperature guage was slightly higher than usual so I suspected that at the point it should be switching on the cooling the fans it was shutting off the engine instead, so yesterday (a hot day) I warmed it up fully then opened up the throttles to 1500 RPM with all the electrics running to simulate load, and it ran through around a dozen heating up - fans on - cooling cycles with no problem at all, and no unusual noises.
So, where do I look?
Is there a chance that the Autobox could shut the engine down to protect itself from damage if, for instance, it had some kind of oil flow restriction or blockage? I can't simulate a hot 'box runnning it in the drive, and don't really fancy testing it again on the road if I know it could stop anywhere!
I guess someone's going to have come across this fault, so over to you Folks...
Cheers,
Julian
Welung666
Re: 3.0 V6 Engine cutting out
« Reply #1 on: 12 July 2010, 21:51:25 »
Click the link below and do a paperclip test, I'll put money on a 19 appearing.... Crank Sensor ;)
greenomegaman
  • Newbury
« Reply #2 on: 12 July 2010, 22:02:46 »
....I had a feeling somone might say that! Would that generate a purely random pattern of cutting out?
Welung666
« Reply #3 on: 12 July 2010, 22:07:55 »
Yes, anytime, anywhere. Very common. If it does turn out to be the crank sensor only buy genuine Vx as the patterns fail regularly.
greenomegaman
  • Newbury
« Reply #4 on: 12 July 2010, 22:17:45 »
Great, thanks for the tip on any replacement...I try to avoid my local dealer where possible!
Do I understand correctly - my flash sequence would be 10 10 1 9 ?
Welung666
« Reply #5 on: 12 July 2010, 22:19:38 »
No, on a 96my you'd have:-
12 12 12 19 19 19 12 12 12
12 being start/end of sequence :y
You may get 31 aswell as it isn't running, ignore that ;)
« Last Edit: 12 July 2010, 22:20:05 by Welung666 »
« Reply #6 on: 12 July 2010, 22:20:00 »
Agreed - check codes - money on 19!!  Def symptoms of dodgy crank sensor - replace with genuine Vx - pattern s are krap!!
« Reply #7 on: 12 July 2010, 22:25:15 »
Sounds like crank sensor, but check for the 19.  Mine did same in France  :-[
If you do get sensor from a dealer, find someone local to you with 'Tradeclub' for decent discount on it :y
EPC has errors when it comes to crank sensors, so ensure they get you right one (certainly post 1998 3.0l take the cheaper sensor, despite what EPC says).
jordan681
  • Sc unthorpe, North Lincs
    • Irmscher 3.0 MV6
« Reply #8 on: 12 July 2010, 22:30:25 »
agreed...   i changed mine the other day, didn't take too long..   I used the guide on here to assist...
Always looking for a bargin..  PM me if u have any uprated Miggy parts...
greenomegaman
  • Newbury
« Reply #9 on: 12 July 2010, 22:58:57 »
Thanks everyone, I'll follow the advice and let you know. Not bad if that's the first sensor thats failed in 115k.
Appreciate the help.
J
