Author Topic: Cat failing on a 2.2  (Read 1964 times)
Erzy
  • Hull
  • Smooth kid !!!
« on: 12 July 2010, 07:57:51 »
Emmisions light came on so went to the garage to get the codes read. Cat below threshold was one and the other was something to do with oxygen sensor reading as a result. Anyway my question is - with the car being due for MOT in a fortnight does anyone know how much a second hand Cat will cost me and how much to fit it. :y
Easy now, theres only one Lanny, the original - the mine!
Re: Cat failing on a 2.2
« Reply #1 on: 12 July 2010, 08:42:49 »
What exactly were the codes?
Cat efficiency only referes to the precat.....not the main cat and hence should not affect the emmisions
« Reply #2 on: 12 July 2010, 08:48:03 »
On a 2.2, aren't the sensors each side of main cat?
Erzy
  • Hull
  • Smooth kid !!!
« Reply #3 on: 12 July 2010, 11:29:54 »
So do we think i need a new cat fitting then ?
« Reply #4 on: 12 July 2010, 12:22:24 »
Could be a sensor issue.  If a new cat does need fitting, better off getting a 2nd hand genuine one than a crappy pattern one. Just ensure flexi is still OK.
« Reply #5 on: 12 July 2010, 12:23:03 »
Did the garage not do any further diagnostics other than read some stored codes :o
« Reply #6 on: 12 July 2010, 13:41:26 »
I would only replace the cat if it's failing MOT emissions - after ensuring it's running correctly, at the right temperature with no fuel trim issues, etc.
Erzy
  • Hull
  • Smooth kid !!!
« Reply #7 on: 13 July 2010, 08:24:21 »
Is there anyone from the forum near Hull who could help me with the diagnostics / live data etc... Like I say, mot looming quickly so I would have to be 100% before paying out for a new cat. :'(
Erzy
  • Hull
  • Smooth kid !!!
« Reply #8 on: 13 July 2010, 10:16:15 »
As earlier mentioned in this thread, where are the sensors on the 2.2 and is 'cat below threshold' code reffering to the main or pre-cats ???
Shrek
  • Fife , Scotland
« Reply #9 on: 13 July 2010, 11:12:12 »
On my 2.2 there is one sensor before the pre-cat and one sensor after the pre-cat .
There is nothing after the main cat . :y
"My Naff Code Reader" and OBD2 readers available .
Erzy
  • Hull
  • Smooth kid !!!
« Reply #10 on: 13 July 2010, 12:03:29 »
So these fault codes cannot determine if my main cat is failing, only that there may be something wrong with my pre-cat ?  How difficult are these to replace ? :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #11 on: 13 July 2010, 16:24:02 »
If the cat efficiency code is bothering you for the MOT get the station to do an emissions test now before you go buying a replacement cat, or put it in for test in the month preceeding the due date.
If it fails you've got time to fix it, if it passes your MOT will be extended to 12 months from the due date anyway.
TuBy's new whipping boy.
