Author Topic: fitting climate control to my CD  (Read 1636 times)
Robski
  • Wigan,Gtr Manchester
« on: 14 July 2010, 18:28:02 »
Can anyone tell me if on a CD model if the wiring harness for climate control is in the dash somewhere or did they use different harnesses for different models.Thanks :y
Re: fitting climate control to my CD
« Reply #1 on: 14 July 2010, 18:41:24 »
sorry, you can't retro fit the Climate dash in mini-facelifts....
« Reply #2 on: 14 July 2010, 18:43:37 »
Think OP meant can he retrofit actual C/C not just the dash instruments. OP in answer to your question. Don`t even attempt it far too much involved
Robski
« Reply #3 on: 14 July 2010, 18:46:54 »
was hoping it was just a case of finding wiring in dash and plug n play :y
« Reply #4 on: 14 July 2010, 18:50:40 »
If only :(
Robski
« Reply #5 on: 14 July 2010, 18:55:24 »
If only :(
Oh well thats put stop to that idea,thought they would of used same harrness through range just not put all the goodies on the CD,as wiring for rear blind is there and heated rear seats :y
M0T0RVATE
  • Orpington
    • 94 Omega Elite Saloon 3L
    • MOTORVATE STUDIO
« Reply #6 on: 14 July 2010, 19:02:41 »
If only :(
Hi
I was going to do this on my '94 Omega.
After a bit of research, found out that there are cables operated by the two temperature controls.
On the climate control system, everything is electrical and therefore some parts of the heater assembly are different.
As other members have siad, too much work perhaps, but not impossible.
Hope that helps
Colin   :y
« Last Edit: 14 July 2010, 19:07:52 by MOTORVATE »
