Author Topic: HELP PLEASE  (Read 1408 times)
duaneyb1
  • eastbourne
HELP PLEASE
« on: 14 July 2010, 18:54:02 »
Hello guys
iam still having problems i have a 3.0 v6 omega ive only had it a week.
the problem is over heating and high pressure in the header tank. the other day the pressure was so high the coolant was pushed out of the header tank with the cap on tite. The coolant hoses get rock solid and i have no thermostat
any ideas coz iam all out :o
Simon72
  • Wolverhampton
Re: HELP PLEASE
« Reply #1 on: 14 July 2010, 18:57:49 »
Sounds like a head gasket problem there.
The compression of one of the cylinders or more is pushing air into your coolant system and pressurizing it.
duaneyb1
  • eastbourne
Re: HELP PLEASE
« Reply #2 on: 14 July 2010, 19:00:37 »
that is what i thought but i had a block test done and the head gasket is fine :o
markspark
  • Bolton
Re: HELP PLEASE
« Reply #3 on: 14 July 2010, 19:02:46 »
could the rad be blocked or the water pump not working correctly just a thought for you
Re: HELP PLEASE
« Reply #4 on: 14 July 2010, 19:03:04 »
You must have a circulation blockage somewhere
duaneyb1
  • eastbourne
Re: HELP PLEASE
« Reply #5 on: 14 July 2010, 19:04:51 »
done a rad flush and the water pump looks new  :-/
markspark
  • Bolton
Re: HELP PLEASE
« Reply #6 on: 14 July 2010, 19:09:25 »
when the engine is running im sure ther should be water running into the header tank the water pump maybe new but could be faulty one
Abiton
Re: HELP PLEASE
« Reply #7 on: 14 July 2010, 19:11:25 »
You need to do a compression test (assuming that the 'block test' was a chemical test in the header tank- not always reliable), or a visual check to be more confident in the HG I think.
By visual check I mean taking out the spark plugs and looking into the holes  with the aid of a bright little torch, a few hours after it was last running.  If you just see nice dry piston crowns, then you can probably say the HG is OK.
Edit: Or, as above, the water pump may not be pumping, even though it looks new.
« Last Edit: 14 July 2010, 19:14:00 by Abiton »
Re: HELP PLEASE
« Reply #8 on: 14 July 2010, 19:15:57 »
What did your rad flush consist of. Top hose off, bottom hose off then hosepipe jobby. If so and the rad does have a blockage the flow of water will just bypass it and exit through bottom outlet. Ideally need to use a quality descaler. Easy test for a blocked rad is to get to operating temp. then use an infrared temperature sensor to check
« Last Edit: 14 July 2010, 19:16:45 by RobG »
tidla
  • solihull
Re: HELP PLEASE
« Reply #9 on: 14 July 2010, 19:20:23 »
the small hose on the header tank when removed should flow when the engine is running( water pump doing its job)
second infer thermo check of rad, aluminium fins in check and not rotted away especially lower down?
duaneyb1
  • eastbourne
Re: HELP PLEASE
« Reply #10 on: 14 July 2010, 19:21:51 »
yes the block test was chemical. and the rad flush was with holts rad flush  :-/
