Author Topic: Auto dimming mirror  (Read 872 times)
steve_daly
Auto dimming mirror
« on: 14 July 2010, 19:44:13 »
As per the title has anyone retro fitted one, if so are they a simple plug-in jobby or will wiring need to be run :question
I see them for sale on Ebay every once and a while, and if I can get one cheap enough and it's not much hastle I may fit one.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Auto dimming mirror
« Reply #1 on: 14 July 2010, 19:47:22 »
there is a (how to) on fitting these, also, The boy has one for sale. :y
« Reply #2 on: 14 July 2010, 19:47:40 »
Doddle to fit. Take connections from roof light (two wires) for just the dim function. If you want the reverse "dim off" function it`s another wire down to the driver`s kick panel (not really worth the hassle). Jaimie (The Boy) has one for sale here http://www.omegaowners.com/forum/YaBB.pl?num=1278955143
Beaten by milliseconds :P
« Last Edit: 14 July 2010, 19:48:32 by RobG »
The Red Baron
« Reply #3 on: 14 July 2010, 19:50:20 »
& you beat me to putting the link up :D :y
http://www.omegaowners.com/forum/YaBB.pl?num=1158088953
for the how to
« Last Edit: 14 July 2010, 19:51:15 by billthebrickie »
steve_daly
« Reply #4 on: 14 July 2010, 19:54:02 »
I must do something wrong when I use the search function, bugger all came up :-?
Cheers, I'll have a read up :y
« Reply #5 on: 14 July 2010, 19:56:05 »
Open another tab, type in "sitewww.omegaowners.com then add on what you are looking/searching for. Seemples :y
