Author Topic: No hot air  (Read 2693 times)
venom
  • South Moreton, Oxfordshire
No hot air
« on: 12 July 2010, 13:22:31 »
With it being a bit colder this morning I put my heating on to warm but all I got blowing out was cold air, set it to hi and still only cold?
Any ideas.
Ken
Re: No hot air
« Reply #1 on: 12 July 2010, 13:37:51 »
Whip the vacuum line off the top of the HBV and plug the line with a small bolt, leaving the HBV clear.  If you now get heat it's either the HBV or the controller giving the wrong output... no vac = heat, vac = cold.
I spent the winter with the pipe disconnected to give me heat, Changed the HBV in the spring so I could turn the heat off !!
HTH  :)
« Last Edit: 12 July 2010, 13:38:10 by entwood »
Re: No hot air
« Reply #2 on: 12 July 2010, 13:54:52 »
Lucky sod, I've got hot air, no chilled air. And leather seats. Hmmmm, bettie swallox....
  • Online Online
Re: No hot air
« Reply #3 on: 12 July 2010, 13:58:54 »
..... Hmmmm, bettie swallox....
Careful you don't get a rash!  ::)  ::)  ::)  ;D  ;D
venom
Re: No hot air
« Reply #4 on: 12 July 2010, 21:13:07 »
HTH  :)
Cheers
Anyway of checking them individually?
Ken
Welung666
Re: No hot air
« Reply #5 on: 12 July 2010, 21:15:45 »
Where are you Venom?
venom
Re: No hot air
« Reply #6 on: 12 July 2010, 21:20:12 »
Oxford mate, why?
Ken
Welung666
Re: No hot air
« Reply #7 on: 12 July 2010, 21:21:31 »
Shame, if you were more local I'd have met up and walked you through it ;)
venom
Re: No hot air
« Reply #8 on: 12 July 2010, 21:24:49 »
Now thats very kind of you, if I get stuck I'll take you up on it as your not to far from me  :y
Ken
venom
Re: No hot air
« Reply #9 on: 12 July 2010, 21:43:44 »
Right just been out and took off the vac pipe and plugged it but still cold  >:( with running temp at 90+
Ken
Welung666
Re: No hot air
« Reply #10 on: 12 July 2010, 21:49:48 »
Can you feel the vacuum on the pipe going into the HBV?
Most likely a blocked matrix or the HBV siezed.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: No hot air
« Reply #11 on: 12 July 2010, 22:19:53 »
Does your car have digital climate control? If so try adjusting the passenger section independently, see if that gets warm...
venom
Re: No hot air
« Reply #12 on: 14 July 2010, 22:42:14 »
Right here we go as this is doing my nut in.
Have no hot air coming through the system, have hot water in both of the matrix pipes so no blockage in that, flushed the system and refilled with fresh antifreeze, took the vac pipe off the hbv and no vac in the pipe it seems but still no hot air, changed the bulbs on the climate control and now cant get any change of air distribution only blows to the screen not anywhere else, tried resetting it by holding OFF & AUTO for 30 seconds but still nothing AAAARRRRGGGGHHHHH !!!!!!!!  >:( >:( >:(
Ken
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: No hot air
« Reply #13 on: 14 July 2010, 22:49:18 »
Did you reconnect the black and yellow plug correctly after removing the panel?  Seems as though you did, but maybe a pin or two isn't making a good contact.
Failing that, your Climate Panel may be knackered?
venom
Re: No hot air
« Reply #14 on: 14 July 2010, 22:54:51 »
Well I did thinks about both of these but thought I might be missing something else, but now you have mentioned it I'll check it all again tomorrow  :y
Ken
