Author Topic: Weird starting problem  (Read 3597 times)
ferrari jason
  • Skelmersdale
« on: 30 June 2010, 19:52:45 »
Right i`m hoping someone could shed some light on my annoying problem My car will start everytime from cold but if say i stop it when warm say to nip in the shop for a few mins it wont start it just spins over . But if i leave it for say 10 mins it fires up straight away any advice would be nice cheers (BTW its my 3.2 ex plod that is having the problem)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Weird starting problem
« Reply #1 on: 30 June 2010, 20:01:46 »
Get the codes read.
My money would be on a dodgy crank sensor.
TuBy's new whipping boy.
ferrari jason
  • Skelmersdale
« Reply #2 on: 30 June 2010, 20:03:56 »
DOH never thought of that lol ill go and have a poke now
Just done the pedal trick i got
0150
0330
0420
« Last Edit: 30 June 2010, 20:20:32 by roverjason »
ferrari jason
  • Skelmersdale
« Reply #3 on: 30 June 2010, 23:32:29 »
Come on guys can anyone explain these codes  :y
« Reply #4 on: 01 July 2010, 08:40:41 »
Seek and ye shall find ... :)
http://www.omegaowners.com/forum/YaBB.pl?num=1220619696
Which, of course, is a part of
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Last Edit: 01 July 2010, 08:41:44 by entwood »
ferrari jason
  • Skelmersdale
« Reply #5 on: 01 July 2010, 12:05:08 »
i found the error code list but its all foreign to me it says on bank 2 is that refering to one of the heads ? i.e passenger side any ideas were the actual knock sensor is located sorry for sounding a dumb ass but i`m totally lost under the bonnet when i comes to sensors etc  :-[
ferrari jason
  • Skelmersdale
« Reply #6 on: 15 July 2010, 17:27:18 »
ok im back again with the same fault but now the orange engine light is on its not lost any power or anything buts it`s worrying me now lol is anyone local to me who could pop over with a code reader or cast an experts eye over it cheers
« Reply #7 on: 15 July 2010, 17:30:54 »
Do the pedal trick again. Probably get 0335
« Reply #8 on: 15 July 2010, 17:32:26 »
Same codes as before or any new ones?
From previous codes, it's not happy with the bank 2 sensor 1 Lambda sensor and bank 2 knock sensor.
P0430 is a cat efficiency code that can be ignored for now.
I would check the wiring to the knock sensor on the passenger side is OK and plugged in for starters. Any sign that the engine loom has been hacked about with during plod decommissioning?
« Reply #9 on: 15 July 2010, 17:37:24 »
Knock sensor shouldn`t give starting problems, should idle and run OK just a noticeable drop in power
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #10 on: 15 July 2010, 17:55:57 »
Just had to replace a knock sensor on mine, as Rob says down on power, fuel consumption up and eml showing.
Replace sensor, reset light and all's good.
I can see it being interesting to replace the no2 sensor though.
« Last Edit: 15 July 2010, 17:56:20 by CaptainZok »
« Reply #11 on: 15 July 2010, 17:59:14 »
CZ. Shouldn`t cause the OP`s hot starting problems though should it :question :-/
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #12 on: 15 July 2010, 18:01:25 »
Doubt it, mine was starting and running fine.
I believe the ECU uses a default setting when it detects a fault.
« Last Edit: 15 July 2010, 18:01:58 by CaptainZok »
« Reply #13 on: 15 July 2010, 18:03:57 »
Gut feeling is 0335, failing C/S
ferrari jason
  • Skelmersdale
« Reply #14 on: 15 July 2010, 18:19:14 »
Strange thing is the starting seems ok now . I`ve bin run ragged by her in doors today looking for a new cooker and it started and run perfect all day was just on the way home and on came the light i`ll double check the codes later i`ll also check the wiring but ive had the car nearly 2 years now so doubt its the wiring but you never know
« Last Edit: 15 July 2010, 18:20:53 by roverjason »
