Author Topic: prop shaft centre bearing advice  (Read 979 times)
nonames
  • Norfolk
« on: 16 July 2010, 13:40:38 »
Ive got a problem with my 2.2 manual sometimes juddering when pulling away (hopefully its not the clutch as ive had it replaced recently i had this problem before it was done)
i think its caused by the prop shaft seal split making the bearing dry.
if it is the centre prop shaft bearing would i just need to replace the seal and gaiter and regrease using a grease gun?
its been like this for a while now and now i have a new clutch and i dont want to put extra wear on it!
any help would be great
Paul
hoofing it
Re: prop shaft centre bearing advice
« Reply #1 on: 16 July 2010, 16:06:05 »
To replace the bearing you need to take the prop and bearing fixings off. these have to be pressed off and on.
have you tryed moving the bearing/prop by hand,just grab prop and give it a good wiggle you should see any wear  :y
