Author Topic: Head Gasket Change  (Read 1132 times)
mrhoots
Head Gasket Change
« on: 17 July 2010, 15:59:59 »
I need to change my head gaskets on my 1999 Elite 2.5 V6, can any one give me full instructions and what I will need to do the job. Thanks in advance.  :-/
coastie123
  • sidmouth, devon
Re: Head Gasket Change
« Reply #1 on: 17 July 2010, 16:46:54 »
check in the maintenance section on how to..
heres the link
http://www.omegaowners.com/forum/YaBB.pl?num=1187928695
theres no pics but a full description.
whats exactly wrong?? i kjnow it sounds like a dumb sort of question but reading through alot of posts the head gaskets rarely fail on v6's...
heres the quote from the guide.....
I will start by saying that Head Gasket failure is extremely rare on the V6 models due to the robust design of the engine. The symptoms often associated with head gasket failure on most engines, can be generated on the Omega’s by a range of other causes.
For example, over pressurising of the cooling system can be caused by blockages, or faulty Heater Bypass Valves, and oil in the coolant can be caused by failed Oil coolers.
I would recommend posting in the general help section with a comprehensive description of your cars symptoms, before condemning the head gasket(s).
« Last Edit: 17 July 2010, 16:50:54 by coastie123 »
« Reply #2 on: 17 July 2010, 16:56:59 »
Why do they need changing, what are the symptoms?
