Author Topic: idle problem  (Read 1047 times)
belairbob
idle problem
« on: 18 July 2010, 12:59:34 »
Hi i have a idle problem it just won,t tick over but drives lovely through gears but when i first start it up it has i high pitched whining noise which goes after about 30 seconds it only does this when cold. any help would be great cheers Bob
belairbob
Re: idle problem
« Reply #1 on: 18 July 2010, 13:01:09 »
Sorry forgot to say it,s a 2.5. v6 and it does cut out all the time cheers
Re: idle problem
« Reply #2 on: 18 July 2010, 13:03:28 »
High Pitched noise is SAI - Secondary Air Injection, nothing to worry about, this can be unplugged if you want.
Idle, take out and clean the ICV - Idle Control Valve, guide is in the maint section.
Also do a paper clip test as well to get your fault codes  :y
Page created in 0.021 seconds with 16 queries.
