Author Topic: Central locking/Power Sounder issue  (Read 1759 times)
Lee Marshall
  • Milton Keynes
« on: 17 July 2010, 13:41:07 »
Hi all,
I have just purchased my third Omega, this one is a facelifted MV6 estate. I am going through it a fixing all the little niggles and would like some advice if possible.
The first issue is that the remote central locking is not working, the light on the key illuminates when the button is pressed but nothing happens.
Then when you unlock the car manually the power sounder goes off until you start the car.
I can live without central locking but the power sounder is doing my head in.
Help/advice?
Second issue to follow.
Thanks
Lee
charlie
  • sunderland
Re: Central locking/Power Sounder issue
« Reply #1 on: 17 July 2010, 13:47:03 »
two ways 1 get fober working 2 leave rear door open then lock car then shut rear door,and a thrid disconnect power sounder then you will have just flashing indictors and no loud siren(poss the horn might go this way)hth charlie :y
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #2 on: 17 July 2010, 13:47:49 »
You may have to remate the Key Fob when in the ignition, fairly sure theres a 'How To' on here.
charlie
  • sunderland
« Reply #3 on: 17 July 2010, 13:50:37 »
or four try zirk way first :-[ :-[
« Reply #4 on: 17 July 2010, 14:04:44 »
Have you checked fuse #20 re; central locking :question
Lee Marshall
  • Milton Keynes
« Reply #5 on: 17 July 2010, 14:10:42 »
Anyone know of the "How to" Zirk mentions? Cannot find it.
Will try all the other options tonight.
Thanks all.
« Reply #6 on: 17 July 2010, 14:15:16 »
To resync, turn ignition to position II press lock/unlock a couple of times. Why wait `till tonight to check the fuse, 10 second job :-?
« Last Edit: 17 July 2010, 14:16:08 by RobG »
Lee Marshall
  • Milton Keynes
« Reply #7 on: 17 July 2010, 14:30:17 »
Because I am at work  ;)
Lee Marshall
  • Milton Keynes
« Reply #8 on: 18 July 2010, 10:54:53 »
Fuse is ok.
Having problems pairing though. I switch the ignition to stage II, PROGRAM appears on the MID. I press the lock/unlock buttons a couple of times then the traffic master renewal message plays!
Anymore suggestions?
Thanks!
Lee Marshall
  • Milton Keynes
« Reply #9 on: 19 July 2010, 11:05:33 »
Bump.
« Reply #10 on: 19 July 2010, 11:15:05 »
Are you sure that the fob is actually paired to the car
FoxyV6
« Reply #11 on: 19 July 2010, 11:19:52 »
pm sent
Lee Marshall
  • Milton Keynes
« Reply #12 on: 19 July 2010, 11:40:56 »
RobG, no I'm not. Have tried the suggestions below but no joy...
zirk
  • Epping Forest
« Reply #13 on: 19 July 2010, 11:58:46 »
From memory, think you need to make sure the drivers door is shut, or open, cant remember.
Chris.
