Author Topic: Door strap  (Read 1554 times)
venom
  • South Moreton, Oxfordshire
Door strap
« on: 19 July 2010, 21:52:41 »
What is the usual fix for the door strap coming away from the A pillar?
Ken
Re: Door strap
« Reply #1 on: 19 July 2010, 21:54:00 »
a welder!
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Door strap
« Reply #2 on: 19 July 2010, 22:34:57 »
The links below provide some useful information. Its probably worth doing the door bush first to see if that cures things and it only takes a minute. If this dosn't do the trick then try the reinforcement plates as in the 2nd link
http://www.omegaowners.com/forum/YaBB.pl?num=1161105965
http://www.omegaowners.com/forum/YaBB.pl?num=1152902108
« Last Edit: 19 July 2010, 22:36:29 by radar »
Re: Door strap
« Reply #3 on: 19 July 2010, 22:38:22 »
...... Its probably worth doing the door bush first to see if that cures things and it only takes a minute. If this dosn't do the trick then try the reinforcement plates as in the 2nd link   .......
It's coming away from the A pillar. The above fix is for the door itself.  ;)
« Last Edit: 19 July 2010, 22:38:57 by Andy_B »
venom
Re: Door strap
« Reply #4 on: 19 July 2010, 22:40:15 »
Cheers Radar but is/has started to split away from the A pillar.
Ken
Re: Door strap
« Reply #5 on: 19 July 2010, 22:42:37 »
I'm going to have to agree with the student ...... again!  :-?  :-?  :-? You need a welder, although one I've seen where it needed work, I reckon you'd need to dig a little to find something decent to weld to.  :-?  :y  :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Door strap
« Reply #6 on: 19 July 2010, 22:45:21 »
Cheers Andy, I think its time for me to go to bed!
Sorry Ken, Tunnies suggestion was spot on. Hopefully someone will come up with other suggestions
Re: Door strap
« Reply #7 on: 19 July 2010, 23:00:18 »
thames valley workshop had roughly welded the one on mine after someone had opened the door a bit enthusiastically. ::) it has started to tear away from the post again. :( think i'll remove it from the pillar, weld a plate over the hole and the re attach the check strap. that should sort it once and all. :)
Welung666
Re: Door strap
« Reply #8 on: 20 July 2010, 12:07:55 »
That's the proper way to do it :y
Shame you're not closer Venom, I'd have done it for you.
venom
Re: Door strap
« Reply #9 on: 20 July 2010, 13:53:13 »
PM sent Lee  :y
Ken
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Door strap
« Reply #10 on: 20 July 2010, 13:58:01 »
I have done two now with pop rivets and they are still good. Just drill out the spot welds and then use a good size pop. ;)
Chimpchoker
  • Hartlepool
  • 1
    • A beautiful omega 2.6 V6
    • Bselfsufficient
Re: Door strap
« Reply #11 on: 21 July 2010, 14:26:58 »
My miggy was recalled for this problem in 2003 and the dealer done a full replacement of the strap. They welded all the way around the replacement parts on the a pillar "to stop it breaking again" it's now starting to break away again and needs welding. I took it back to the dealer and although it is now 7 years and 55k miles since it was done they said they would do it again for £25 + vat.
windup merchant of the first order
