Author Topic: Coolant Warning  (Read 1079 times)
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
Coolant Warning
« on: 18 July 2010, 23:01:30 »
Just returned from my holidays today, warning coolant level showed. Coolant level OK temp gauge  OK, got me home :y.
 What do I need to do, to replace sensor, or could
there be another reason for the fault showing?
I drive 2.2 on 02 plate.
« Last Edit: 18 July 2010, 23:02:47 by DaveA »
Regards
    Dave
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: Coolant Warning
« Reply #1 on: 18 July 2010, 23:09:56 »
You may have a sticking float or loose connection under header tank hth :y
DaveA
  • Leicestershire
Re: Coolant Warning
« Reply #2 on: 22 July 2010, 10:32:52 »
Help Please
    Is the coolant sensor normally open or closed.
have expansion tank on bench, I filled it with water. checked it with meter which (peeped) Let it empty (nothing). Is this correct. Float ok.
Regards
    Dave
Re: Coolant Warning
« Reply #3 on: 22 July 2010, 11:06:42 »
Help Please
Closed when the level is OK hence the sensor can be by-passed by bridging the connector under the bottle. A nice new shiney header tank is around £30  :y
Yes!  :y
« Last Edit: 22 July 2010, 11:07:37 by Andy_B »
DaveA
  • Leicestershire
Re: Coolant Warning
« Reply #4 on: 22 July 2010, 12:20:08 »
Thanks Andy
       Shiny new tank ordered :y
Regards
    Dave
