Author Topic: Brake Bleed Nipple bolt  (Read 2615 times)
« on: 20 July 2010, 21:37:05 »
Are these sold individually? or are sold with the entire caliper?
Re: Brake Bleed Nipple bolt
« Reply #1 on: 20 July 2010, 21:58:14 »
bleed nipples are sold seperately .... you need to be able to get the old one out without shearing the head off if it siezes  ;)
http://shop.ebay.co.uk/?_from=R40&_trksid=p3907.m570.l1313&_nkw=bleed+nipple&_sacat=See-All-Categories some are s/s  :y
« Last Edit: 20 July 2010, 21:59:10 by Andy_B »
« Reply #2 on: 20 July 2010, 22:08:14 »
Cheers Andy  :y
Problem is its been rounded off due to rust, the standard (8mm?) spanner works on one side, but slips on the other, can't get the size smaller on.
Suspect a 'magic' socket should cut in, or use of plyers should get it going, but need replacement.
I'm not sure if its M7 or M8 though  :-/
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #3 on: 20 July 2010, 22:09:58 »
A small stilson?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #4 on: 20 July 2010, 22:09:59 »
Cheers Andy  :y
Give it a damn good soaking with plus gas first.
You don't want it to shear the end off.
TuBy's new whipping boy.
« Reply #5 on: 20 July 2010, 22:13:13 »
Cheers Andy  :y
Student remember - WD40 it is  ;D
« Reply #6 on: 20 July 2010, 22:14:32 »
get some plusgas for that.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #7 on: 20 July 2010, 22:14:51 »
Cheers Andy  :y
Just "borrow" some from your uncle TB. :y
« Reply #8 on: 20 July 2010, 22:15:04 »
Wot he says. Build up a well of bluetak or plastercine around the nipple & fill it with Plusgas, & repeat  ;). Sometimes 'judicious' tapping with a small hammer can help shock it into submission. If it shears, you either need A N Othe caliper, or a machine shop to drill it out carefully.
« Reply #9 on: 20 July 2010, 22:16:16 »
Cheers Andy  :y
I'll give you a can of Plusgas if you're going to Newent.  :y  :y
« Reply #10 on: 20 July 2010, 22:20:01 »
Use a hex socket to get it free.
« Reply #11 on: 20 July 2010, 22:20:26 »
Cheers Andy  :y
Its about time we argued in person is it not?  ;D
Can't make Newent, due to fly to Tokyo on 4th September
« Reply #12 on: 20 July 2010, 22:26:24 »
M8  :y Use a hex socket, but not a great big 1/2" drive ... you'll shear it, and carefully try it back & forward. Chances are it'll undo without breaking.
« Reply #13 on: 20 July 2010, 22:32:58 »
Cheers  :y
I don't think its seized, just corrosion has made it 'un-gripale' with the spanner  :(
« Reply #14 on: 20 July 2010, 22:45:30 »
Cheers  :y
Using a hex socket will be better than an open ended spanner.  ;) And smear a little copper grease on the new one when you fit it.  :y
Page created in 0.021 seconds with 16 queries.
