Author Topic: due  (Read 948 times)
leedsleedsleeds
due
« on: 22 July 2010, 20:03:15 »
due to heavy recent rain,back foot well really wet only on passenger side.sure door and window closed propley,any idears wear coming from and how to stop  cheeers
charlie
  • sunderland
Re: due
« Reply #1 on: 22 July 2010, 20:05:37 »
Lift the carpet there plugs,grommits that might have come loose dislodged or have a look from underneath might be easier then it should become clear
« Last Edit: 22 July 2010, 20:06:50 by charlie »
Re: due
« Reply #2 on: 22 July 2010, 20:09:09 »
had same problem, check underneath the car under the foot well, the carpet lugs designed to hold the carpet can disappear, i had a hole in the floor!
Sealed it with some arraldite, can see the hole here, and where its wet:
« Last Edit: 22 July 2010, 20:09:54 by tunnie »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: due
« Reply #3 on: 22 July 2010, 21:10:56 »
Does the 2.2 have the same scuttle drain problems as the 2.5  2.6? If so check under the pollen filter see if the drain is clear
Re: due
« Reply #4 on: 22 July 2010, 21:24:03 »
yup
