Author Topic: Auto gear selector query.  (Read 1067 times)
GaryBC
  • Egham, Surrey
« on: 23 July 2010, 11:49:53 »
Hi all.
I need to get the ashtray assembly out. To make it easiest I want to pull the gear lever right back out of the way.
If I turn the ignition off with the lever in the rear-most position, will I then be able to get it back to "N" to start the car again?! It won't lock there, will it?
Daft question maybe, but I don't want to get stuck!
Cheers,
Gaz
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: Auto gear selector query.
« Reply #1 on: 23 July 2010, 12:43:44 »
Shouldn't be any problem ASAIK. Ive had to do same when I've been mucking around with the CD magazine.
« Reply #2 on: 23 July 2010, 13:06:32 »
Ign off, in P.
Lift up leather gaitor around gearstick (pull it upwards at end nearest ashtray). On left og gearstick, near were it meets tunnel, is a yellow level. Press that, and move gearstick.
Oh, and ensure the handbrake is on and working, or chock the wheels!
GaryBC
  • Egham, Surrey
« Reply #3 on: 23 July 2010, 15:15:38 »
What if I switch off with the gear lever in "1"?
Welung666
« Reply #4 on: 23 July 2010, 17:21:36 »
Don't switch it off in gear!!! Switch it off in N. The gear lever only locks in park so you're safe moving between the rest when not running.
GaryBC
  • Egham, Surrey
« Reply #5 on: 23 July 2010, 23:01:35 »
Aha! I didn't realise that! Thanks.
