Author Topic: Car and steering wheel vibrating!!  (Read 1674 times)
smithpa7
« on: 23 July 2010, 23:39:01 »
Hi Guys, I need your advice :)
My 3.0 auto estate has started to vibrate, as though the wheel nuts are loose. It is mainly through the steering wheel. It is worst when accelerating slowly from 45- 55 mph. It also seems to happen when cruising at a steady 80 ( only on unrestricted autobahns, of course!). I have checked the wheel nuts and they are tight. When I bought the car 10 months it had a very slight vibration, however it is now getting progressively worse :'(
Can anyone please help??? :(
Re: Car and steering wheel vibrating!!
« Reply #1 on: 23 July 2010, 23:42:44 »
wheel balancing on the front - or lack of - will cause a shake through the steering wheel at various speeds, generally you can 'drive though it'
rear wheels needing balancing will shake the whole car at a specific speed. You may have lost a weight.  :y
smithpa7
« Reply #2 on: 23 July 2010, 23:49:49 »
Thanks Andy, I will visit my local Kwik Fit over the weekend and get it checked out  :y :y :y
« Reply #3 on: 24 July 2010, 00:17:28 »
Kwik Fit  :-? :-?A local independant would be better  ;)
johny5
  • Portsmouth, Hampshire
« Reply #4 on: 24 July 2010, 00:20:11 »
if its lost a weight surely it wont progresivly get worse? itll either vibrate or it wont.
« Reply #5 on: 24 July 2010, 00:24:59 »
out of balance wheels tend to show at certain speeds, and the become better once you've gone through that speed. I recently had a vibration problem with my Astra at 65mph-ish. When balanced all was back to normal ........ it was still a slow noisy diseasal Astra  ;D ;D ;D
« Last Edit: 24 July 2010, 00:26:43 by Andy_B »
« Reply #6 on: 24 July 2010, 00:25:21 »
Depends on the amount of weight(s) and where they were fitted, at certain speeds you could drive throught the vibration, add a a weight to sort it, if they get it wrong you might get a vibration at a tottaly differt speed.
Either way it's best checked out before and wear takes place. :y
smithpa7
« Reply #7 on: 25 July 2010, 13:21:10 »
Well guys, I took the car to my local Kwik Fit (this one does have a good reputation). They told me both front wheels are buckled! They balanced them both and the transformation is remarkable :) :) I really thought it was something more serious, as the vibration was very pronounced.
This has highlighted a failing by North East Tyres who fitted two new tyres on the front about 4 months ago. They failed to balance the wheels after fitting the tyres. There wasn't any weights on either wheel......I won't be using them again >:( >:( >:(
Thanks to all for your great help and advice.
 Another pat on the back for the OOF :y :y :y
Dave Elite
  • Ellesmere Port
« Reply #8 on: 25 July 2010, 14:11:03 »
I did'nt think there was such a thing.
smithpa7
« Reply #9 on: 25 July 2010, 15:49:38 »
 ;D ;D ;D I have known the Manager for 15 years and he has always looked after me. He even sent me elsewhere for a car battery when he knew I could get a better deal :y :y
« Reply #10 on: 25 July 2010, 15:59:41 »
pre-facelift MV6 alloys are like toffee, Elite wheels though are much stronger. I would not trust Kwik Fit, check out Wheels in Motions new list of approved franchises, should be one near you  :y
« Reply #11 on: 25 July 2010, 16:09:36 »
So just balancing is not the long term, or even short term answer then? :-/ :-/
Buckled wheels will do you no favours in terms of tyre wear, suspension set up, and in general when at speed ::) ::) ::)
Trust Kwik fittup to come up with a bodge solution!  Says it all ::) ::) ::)
  • Auckland
    • Mazda MPV
« Reply #12 on: 25 July 2010, 17:54:54 »
Do you have a link to this list?
smithpa7
« Reply #13 on: 25 July 2010, 19:27:03 »
Andy see link below.
http://www.blackboots.co.uk/order.php?step=5
If you scroll down you will see the complete list. My nearest one is Bolton!!!
I will have to find a couple of Elite wheels, how can I tell If second hand ones are buckled or not?
I don't suppose new wheels exist anymore? :'(
  • Auckland
    • Mazda MPV
« Reply #14 on: 25 July 2010, 19:36:03 »
Thanks Zombie.
Nothing in Devon or Cornwall. The nearest to me is Gloucester which Google Maps tells me is a 300 mile round trip :(
