Author Topic: V6 Cam Cover Gaskets Special Offer  (Read 2366 times)
andyc
  • Norfolk
« on: 24 July 2010, 09:01:20 »
OK following on from the thread about cam cover gaskets and prices i'll do this for OOF members
OE Cam Cover Gasket Kit for V6 Engines
Kit Contains the following
2 x 90511451 Cam Cover Gaskets £22.53 each (£45.06)
16 x 90411826 Cam Bolt Seals £0.14 each (£2.24)
1 x 90485251 RTV Sealant £3.25
1 x 9118135 Pack of Plenium O Rings £9.44
Parts Total £59.99
Postage £3.00
VAT @ 17.5% £11.02
Total £74.00
Part will only be at these prices if brought as a complete kit and is for Vehicle upto chassis 21999999 after which the gaskets change
The above works out to 15% off Vauxhalls trade prices except the RTV which is 10% off
To order either call 01284 777254 and ask for me or email
andyclears@drivevauxhall.co.uk
Cheers
Andy
« Last Edit: 24 July 2010, 09:03:08 by andyc »
Thetford. Norfolk
Re: V6 Cam Cover Gaskets Special Offer
« Reply #1 on: 25 July 2010, 15:21:56 »
Parts Total £59.99
Postage £3.00
VAT @ 17.5% £11.02
Total £74.00
Cheers
Andy
B*gger - Just bought some Andy!!  Maybe OOF shop may be interested?
« Reply #2 on: 25 July 2010, 15:51:05 »
Andy, I think the following is a much more useful kit;
•Rocker gaskets 2 sets: 90511451.
•O-rings 16 off: 90411826.
•Sealent, Black (not the Green stuff!) 1 off: 90485251.
•Breather bridge to plenum seal 1 off: 90467543.
•Breather bridge to throttle O ring 4 off 90500983.
I have yet to ever need to replace plenum O rings.  :y
  • Auckland
    • Mazda MPV
« Reply #3 on: 25 July 2010, 16:47:21 »
Is the 'breather bridge' the black plastic cover that says 'Ecotec' which the 4 vacuum pipes connect to?
« Reply #4 on: 25 July 2010, 18:07:33 »
Yes.
So the above list will allow you to do the cam covers and clean the breathers
  • Auckland
    • Mazda MPV
« Reply #5 on: 25 July 2010, 18:15:59 »
Yes.
I have been lucky (so far) as every time I have had a 'breather bridge' off to clean it the seals have been just about re-usable. I agree that they are more likely to need replacing than the plenum O rings.
« Reply #6 on: 25 July 2010, 22:15:43 »
Yep I agree.  However in view of the cost of the camcover gaskets it may be helpful to offer a kit containing 1 off gasket, 8 off orings and black sealant - particularly as I have seen a number of V6s where only one cam cover leaking (usually the passenger side  :()
GaryBC
  • Egham, Surrey
« Reply #7 on: 26 July 2010, 09:19:48 »
This suggestion defo gets my vote as, at the price of these gaskets, I don't plan on changing the one that's not leaking!
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #8 on: 26 July 2010, 11:31:54 »
is there a 'way' to know if they are leaking - apart from seeing loads of oil down the side or something - whats the give away (e.g. on my A8 its the fact the car smells like the inside of a workshop!)
« Reply #9 on: 26 July 2010, 11:39:52 »
Oil in plugwells, or seeping onto exhaust manifold.  If the o-rings go, you can see seeping from camcover bolts.
« Reply #10 on: 26 July 2010, 19:08:00 »
And the smell of burning oil as it tends to drip onto the manifolds!!
