Author Topic: Brake pad sensor  (Read 872 times)
Nickbat
Brake pad sensor
« on: 27 July 2010, 17:21:23 »
I was told by the fitter who changed my pads last year that my '02 2.6 V6 has only one pad sensor on the nearside. Can anyone confirm that this is the case?
If it is, then I have a small problem. The sensor was fubared and, as neither he nor I had a spare, he tied the cable back.
I now have a replacement sensor, but have yet to fit it. However, I have recently started to get a "Brake Pad" message displayed on the MID. It comes and goes. I know the pads are not worn right down and  that the sensor is tied back securely (just checked). What could be causing this fault?  :-?
Re: Brake pad sensor
« Reply #1 on: 27 July 2010, 17:22:53 »
on car your age there is only one sensor  :y
How was it taped back? the wires must be stripped back, and be made to touch to close the loop. If they come apart, the error will come back  :y
Nickbat
« Reply #2 on: 27 July 2010, 17:48:59 »
Just tied back with a cable tie, Tunnie.
« Reply #3 on: 27 July 2010, 17:53:52 »
what was done with the actual sensor? was it cut off and had wires tied together?
« Last Edit: 27 July 2010, 17:54:06 by tunnie »
Nickbat
« Reply #4 on: 27 July 2010, 17:59:23 »
No, from what I can see it has the remains of what looks like (but I know isn't) a rusty spade terminal.
« Last Edit: 27 July 2010, 17:59:38 by Nickbat »
  • Online Online
« Reply #5 on: 27 July 2010, 18:09:02 »
buy a new one, plug it in & clip it to the pad.
Nickbat
« Reply #6 on: 27 July 2010, 18:49:00 »
Got a new one here. Just need to find a minute to put it on. I assume it's very straightforward.
  • Online Online
« Reply #7 on: 27 July 2010, 20:30:47 »
The sensor has a 'peg' that's split in 4 & just clips into the butterfly shaped anti-rattle spring of the pad via the hole in the caliper.  :y
