Author Topic: code won't go away.  (Read 2219 times)
duggs
  • Felixstowe
    • BMW 3.0 Sport
code won't go away.
« on: 27 July 2010, 18:40:45 »
Had crank sensor changed today at a cost of £111.00. Car runs perfectly but no matter what the mechanic did the 19 error code will not disappear. In fairness most likely after market sensor and non vauxhall code reader. Any thoughts.
Re: code won't go away.
« Reply #1 on: 27 July 2010, 18:42:26 »
 :o :o :o
Most cheapo tech2's can reset codes, it should not come back  :y
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #2 on: 27 July 2010, 20:10:13 »
In fairness, if she continues to run well I'm not that bothered  if it shows a fault code on a code reader or not. Seem to remember my wifes Vectra had a fault code generated a year before and that too ran fine.
« Last Edit: 27 July 2010, 20:11:22 by duggs »
Omegafantasy
  • Oslo, Norway
« Reply #3 on: 27 July 2010, 20:20:42 »
My experience is that a code 19 will always be present if the engine isn't running (you won't get pulses of the crank when its not turning). Start her up and re-read.
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #4 on: 27 July 2010, 20:24:26 »
Hmmmmmmmm !   Now thats an interesting one....and booger me...can't remember if the engine was runnin' or not when he read the codes in front of me.
OOOOOO well !  Lets see how it goes...Gulp !!!
« Reply #5 on: 27 July 2010, 20:43:45 »
If the engine is not running, then you get a 30 something code.
Omegafantasy
  • Oslo, Norway
« Reply #6 on: 27 July 2010, 20:48:48 »
Hmm.. My car gives me a 19 when engine is stopped, but goes away when started. Same with my mates 4 pot  :-?
Guess they're both on their way out then.
« Reply #7 on: 27 July 2010, 20:51:45 »
I've ever done the paper clip test other than a few months ago when the car died showing all the symptoms of a failed crank sensor. I got a code 19 but didn't check again when it was replaced.  :-/
« Reply #8 on: 27 July 2010, 21:46:52 »
I've had a code 19 for 18 months and 2 different sensors... Never went away but runs fine ::) ::)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #9 on: 27 July 2010, 22:06:28 »
He he he...THAT'S go enough for me Paul. Thk u.
« Reply #10 on: 27 July 2010, 22:08:05 »
Not saying yours will be the same but, as you know, mine runs fine :y :y
« Reply #11 on: 27 July 2010, 23:22:54 »
For clarity...
19 - Incorrect rpm signal - fubar crank sensor
31 - No RPM signal - engine not running
I would try to get that code cleared, then see what comes back.  And we say genuine crank sensors for a reason ;)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #12 on: 28 July 2010, 00:14:39 »
Eledgedly he cleared the code, went for a run without incident and the code was back. ONLY got her back tonight so I'll see how it goes, if at all, over the next couple of days.
Hopefully it will replicate LD's car and won't give a stuff whether the code is showing up or not.
« Reply #13 on: 28 July 2010, 08:53:17 »
We've cleared mine a few times now and it still comes back. The Master has suggested I re-fit it to see if it makes a difference. For clarity, I have a Genuine Vx sensor fitted and the previous one was an identical Bosch sensor (with the Vx Part Number stamped on it!) as it was all that was available at the time.
« Reply #14 on: 28 July 2010, 09:30:17 »
£111 for a non gen crank sensor fitted - thieving shits!
