Author Topic: Easy way ???  (Read 2480 times)
ianc
  • moreton merseyside
Easy way ???
« on: 28 July 2010, 16:36:42 »
Is there an easy way to get oil filter off car, wont go on ramps at home,do i have 2 take front bumper off.tried jacking it up,but not much room to get under car.please help ta ianc
Re: Easy way ???
« Reply #1 on: 28 July 2010, 16:38:35 »
jack and axel stand?
Re: Easy way ???
« Reply #2 on: 28 July 2010, 18:37:14 »
Yep, if you jack up at the front jacking point and place axle stands under the front subframe members you will be able to gain sufficient access (unless you have a large beer gut!! ::) ::) :D :D)
duggs
  • Felixstowe
    • BMW 3.0 Sport
Re: Easy way ???
« Reply #3 on: 28 July 2010, 18:40:28 »
Cheap way !  If you're lucky.  Find a high curb, ideally in a quiet spot. Plonk one side of the car, length ways up on the curb. The rake of the angle might give you enough space to crawl under.
Works in an emergency but tis somewhat dangerous all round though ?
Re: Easy way ???
« Reply #4 on: 28 July 2010, 18:42:06 »
.... but tis somewhat dangerous all round though ?
How? :-/ If the car has all four wheels on the ground it couldn't be safer. :-?
Abiton
Re: Easy way ???
« Reply #5 on: 28 July 2010, 18:43:32 »
Not if the wheels fall off!  :D
tidla
  • solihull
Re: Easy way ???
« Reply #6 on: 28 July 2010, 18:49:15 »
if you use the bus stop kerbs on a main road :D
martronn
Re: Easy way ???
« Reply #7 on: 28 July 2010, 18:55:56 »
if you changing the filter and have a new one?? if you able to reach the filter form the bonet?? you cab knock a skrewdriver thru the filter and just twist it off. but you hafe to have a new filter becouse you will destroy it when you use this metode. if this is what you mant??  :y
Re: Easy way ???
« Reply #8 on: 28 July 2010, 20:15:53 »
You will not be able to do that on a V6, and especially if it has a paper filter within a canistor housing ;) ;)
Bent valve
Re: Easy way ???
« Reply #9 on: 28 July 2010, 20:32:03 »
Do not take front bumper off. this will not help at all.May as well take rear bumper off.Best to jack car up and use axel stands or wooden blocks. Maybe remove nearside front wheel for easier accsess also.Failing that take it to Kwik fit and get them to do it
« Last Edit: 28 July 2010, 20:33:01 by Bent_Valve »
Re: Easy way ???
« Reply #10 on: 28 July 2010, 20:38:39 »
That is where your good advice ceased :o :o :o :o :D :D ;)
If you want trouble with replacing your oil filter in the future, take it to Kwik Fittup!! :-X :-X :-X :D ;)
« Last Edit: 28 July 2010, 20:39:07 by Lizzie_Zoom »
Bent valve
Re: Easy way ???
« Reply #11 on: 28 July 2010, 20:45:18 »
I think removing oil filters is about all they are good for!
Agemo
  • Cleethorpes
  • Insignia
Re: Easy way ???
« Reply #12 on: 28 July 2010, 20:50:05 »
      Easy enough on axle stands. Just wondered why your car won't go on ramps.  ::)
Re: Easy way ???
« Reply #13 on: 28 July 2010, 20:55:36 »
Well BV I reckon if I was (heaven forbid!!) ever to let those monkeys loose on my canistor type oil filter they would quickly be telling me "the canistor body is moving..........we need to fit a conversion for £XXX", or it would be "the canistor body has sheared............major problem........you'll have to have it transported to a garage who can repair it!"..........or "we replaced the filter with a cartridge type [but they have never been near your canister type filter!!]" etc, etc, and not forgetting when you come to replace the filter if actually put on by them........the next garage says "who ever did the last change damaged the housing..........will have to replace for £XXX"
All fiction of course, but remembering my, and my family's, experiences with these monkeys almost guaranteed scenarios :D :D :D ;)
« Last Edit: 28 July 2010, 20:56:36 by Lizzie_Zoom »
Bent valve
Re: Easy way ???
« Reply #14 on: 28 July 2010, 20:56:33 »
Actually he says it wont go on ramps at home. it could be that they are shit ramps, maybe thats why he was thinking of removing the bumper... if that is the case just get some short lengths of scaffold plank or similar and use them as a run up on to the ramps :y
