Author Topic: Crank shaft sensor.....  (Read 775 times)
bertiecbx550
« on: 29 July 2010, 23:59:38 »
Ok its all done and dusted i`ve replaced the crankshaft sensor and the Big E seems to be running ok again...Apart from the gearbox fault that keeps coming up after a drive like yesterday on the way back from the west mid safari park....I pulled over and turned the ignition off and waited for a couple of mins and then fired her back up again and no gearbox warning or check on the M.I.D. and she drove ok again....No fault codes either when i did the paperclip test at home....Puzzling that one....
Re: Crank shaft sensor.....
« Reply #1 on: 30 July 2010, 05:51:16 »
.......Apart from the gearbox fault that keeps coming up  ......No fault codes either when i did the paperclip test at home....Puzzling that one....
Paper clip test only does engine codes  ;)
Welung666
« Reply #2 on: 30 July 2010, 06:26:32 »
Next time I'm passing I'll read off your gearbox codes :y
