Author Topic: KeyFob  (Read 1071 times)
Deathowl
  • Neath, South Wales
KeyFob
« on: 26 July 2010, 11:55:54 »
Alright OOF People,
I have replaced the battery in my key fob and it locked the car when i was in the car but when i left the car i can not lock or unlock the car on the fob any ideas
Re: KeyFob
« Reply #1 on: 26 July 2010, 11:58:00 »
Are you saying its a problem with range?
Receiver is in drivers footwell...
« Last Edit: 26 July 2010, 11:58:16 by TheBoy »
Re: KeyFob
« Reply #2 on: 26 July 2010, 11:58:30 »
sounds like it needs a resync.
key in ignition, doors shut
turn key to 1 or 2, then press a button, doors should lock and unlock, job done
Deathowl
Re: KeyFob
« Reply #3 on: 26 July 2010, 12:08:00 »
press the button on the key fob ya
Deathowl
Re: KeyFob
« Reply #4 on: 30 July 2010, 21:05:02 »
right tried that put the key in and turned it to one and 2 and the doors did not lock any ideas the key fob still does not work.
Re: KeyFob
« Reply #5 on: 30 July 2010, 21:27:26 »
Take the key apart & check to see if the battery holder is loose. If it is, then the contacts to the PCB may be broken/ giving an intermittent power supply? :-/
Page created in 0.029 seconds with 20 queries.
