Author Topic: Re-setting airbag light?  (Read 1269 times)
littleimp
« on: 28 July 2010, 15:33:56 »
Is this a tech 2 job or can anyone recommend an ebay obd that will fix this?
I replaced the ignition barrel and turned on ignition without the drivers airbag plugged in not realising this will keep the airbag light lit when put back together. My fault I know, should have dis-connected battery. I'm looking at getting a scanner though so this gives an excuse.
p.s. Forgot to mention it's a 'r' reg 2.5 elite.
« Last Edit: 28 July 2010, 15:35:12 by littleimp »
Re: Re-setting airbag light?
« Reply #1 on: 28 July 2010, 15:35:51 »
yup, tech2, worth posting up your location, we may have one near you  :y
littleimp
« Reply #2 on: 28 July 2010, 15:59:25 »
I'm in clacton-on-sea, essex, uk
Agemo
  • Cleethorpes
  • Insignia
« Reply #3 on: 28 July 2010, 21:01:39 »
You will find that ""My Naff Code Reader"s" or similar will reset the light,  it would probably cost more for stealer to reset than to buy one.  ::)
littleimp
« Reply #4 on: 01 August 2010, 17:59:12 »
Yep, been looking into that one and will go that route. Will come in handy later on so seem the better investment.
