Author Topic: Facelift door mouldings removal?  (Read 1662 times)
Sir Sideways
  • Sideways in Staffordshire
    • PFL 3.0 Auto Elite Estate
« on: 31 July 2010, 11:05:52 »
How do you remove facelift door mouldings? does the door card need to come off?
Thanks
Jim
Re: Facelift door mouldings removal?
« Reply #1 on: 31 July 2010, 11:10:28 »
Hi Jim.
If your on about the plastic wood bits the door card has to come off, however, the plastic wood bits have what looks like a large plastic rivet which when removed would be difficult to re-attach.
nell77
  • manchester
« Reply #2 on: 01 August 2010, 13:08:27 »
or if you on about the ones on the door outer you will need a 10mm socket or spanner for the front indicator mouldings and a Torx for the door mouldings one at each end then slide the trim to get it off.
nell77
  • manchester
« Reply #3 on: 01 August 2010, 18:17:22 »
Think the torx is a T25
