Author Topic: alloy wheel repair  (Read 939 times)
krivoyrog25
alloy wheel repair
« on: 01 August 2010, 19:10:23 »
Hi All,
just back from trip to Ukraine. Omega ran great. unfortunately I hit a pothole not far from the border on the way back, the tyre appears still ok, but there's a dent on the rim itself (inside). Can these types of dents be righted like you can on a steel rim? I have the 100 years anniversary rims( mine is a 08/99 opel omega).
3909km in 7 days, average 68km/h, 7.3L/100KM
Re: alloy wheel repair
« Reply #1 on: 01 August 2010, 19:42:21 »
Hi All,
I believe that you can repair some quite serious damage to alloy rims, but I would think it all depends how badly you've bent it. I would think it'd be cheaper to find A N Other rim for less that you'd pay for for your bent rim to be repaired.  ;)
« Last Edit: 01 August 2010, 19:42:37 by Andy_B »
« Reply #2 on: 02 August 2010, 10:23:54 »
General rule is if it's cracked bin it, bent is repairable. As you drove on without a puncture, presumably, the wheel should be repairable.
One of mine has a slight ding on the inside rim, no noticeable affect, so left it. :-/
« Reply #3 on: 02 August 2010, 20:09:23 »
can be repaired..if necessary must be heated to a degree for repair (so repaint will be necessary also)
