Author Topic: How Do You Adjust the Camber on the Rear Wheels???  (Read 1869 times)
Jim
  • Glasgow
    • Irmscher 3.2 V6 Elite
    • My Vauxhall Omega's
« on: 03 August 2010, 01:22:18 »
As the title, How do you adjust the camber on the rear wheels?? Any ideas
Re: How Do You Adjust the Camber on the Rear Wheels???
« Reply #1 on: 03 August 2010, 02:34:00 »
Rear track rods, but they are primarily for toe, adjustment also affects camber, so a compromise may need to be found, if that makes sense?
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #2 on: 03 August 2010, 04:32:16 »
This is best left to experts like WIM. The majority of centres who claim to do wheel alignment are not really experts. Too manhy times have I had my alignment done only to have to take it elsewhere because it was not right. Eventually I found somwhere that knew what they were doing. S**tFit were the worst closely followed by the dreaded H.
As already said, it can be done by adjusting the rear track rods but it is not something I would do because it will affect the tyre wear and handling whichever way you adjust it away from its recommended setting.
This should only be done if there is a real problem. Are the rear doughnuts worn at all?
GudLuk
wheels-inmotion
« Reply #3 on: 03 August 2010, 09:00:50 »
You cannot directly adjust the camber, moving the toe will influence the camber but mildly.
If both the cambers are wrong then it's probable the coils have sagged, if it's just the one side then there's a bend, that's assuming all mechanical areas have been met.
Jim
  • Glasgow
« Reply #4 on: 03 August 2010, 10:49:30 »
Its both sides on the rear, its a company in Glasgow that have a 4 wheel Geometry machine, but because I have a full irmscher suspension kit on the car they don't have the correct settings, but i've emailed irmscher(UK) to get the settings
« Reply #5 on: 03 August 2010, 11:40:23 »
Tony at wim will help I think, give him a ring?
Jim
  • Glasgow
« Reply #6 on: 03 August 2010, 15:14:51 »
Will do, cheers :y
