Author Topic: RTV curing time  (Read 1022 times)
GaryBC
  • Egham, Surrey
RTV curing time
« on: 04 August 2010, 10:27:23 »
I'm doing my rocker cover gaskets at the weekend.
When I apply the (black) RTV, roughly how long do I have between squeezing it out of the tube, and it starting to go off?
Re: RTV curing time
« Reply #1 on: 04 August 2010, 11:21:04 »
Long enough to fit them don't worry. With cable tray pre tied up out the way and well cleaned heads just apply and fit with seals pre fitted to the covers. I suppose 20 mins to half an hour before it thinks about setting. So by the time it's re built you could drive it I guess? Although I left mine overnight, I was knackered.  ;D
GaryBC
  • Egham, Surrey
Re: RTV curing time
« Reply #2 on: 04 August 2010, 13:18:50 »
It's not so much the curing time post fitting I'm thinking of, it's the time between applying it to the mating faces and it starting to go off. Some really quick setting sealants require you to work quite fast - I was wondering if this is one of them.
Re: RTV curing time
« Reply #3 on: 04 August 2010, 14:57:23 »
You have approx. 20 minutes before a skin starts to form Gary  :y
