Author Topic: Steering wheel removal?  (Read 1840 times)
beemerdevil
« on: 03 August 2010, 19:20:09 »
Hi guys
What is the correct/safe way to remove steering wheel? (airbag?) and also, is the wheel on splines or is it a 'hex' shape shaft? TIA  :y :y
Re: Steering wheel removal?
« Reply #1 on: 03 August 2010, 19:26:03 »
Hi guys
Disconnect the battery, you've got 15 secs from turning theignition off & taking the earth lead from the battery or the alarm will sound.
Go & have a drink/smoke/walk round the block  ;)
Remove the two Torx head screws from behind the wheel & remove air bag. Unplug it from the airbag, NOT the wheel.
The wheel is held by a tapered spline. Slacken but don't completely remove the lock nut from the centre of the wheel. If you're lucky, the wheel will come off with a 'judicious' clout from behind using your palms ..... this is why you leave the nut on to preserve your smile  ;)  ;)  ;). If you're not lucky, you'll need a specific steering wheel puller.  :y like this one ...... http://cgi.ebay.co.uk/Laser-GM-Vauxhall-Steering-Wheel-Puller-/160463335121?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item255c5c2ed1
« Last Edit: 03 August 2010, 19:27:14 by Andy_B »
Hannah Judes Dad
    • the misses round the bend
« Reply #2 on: 03 August 2010, 19:28:08 »
Hi guys
The wheel is held by a tapered spline. Slacken but don't completely remove the lock nut from the centre of the wheel. If you're lucky, the wheel will come off with a 'judicious' clout from behind using your palms ..... this is why you leave the nut on to preserve your smile  ;)  ;)  ;). If you're not lucky, you'll need a specific steering wheel puller:y like this one ...... http://cgi.ebay.co.uk/Laser-GM-Vauxhall-Steering-Wheel-Puller-/160463335121?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item255c5c2ed1
Or be careful with a hammer !
« Reply #3 on: 03 August 2010, 19:30:00 »
but the bit you need to hit is padded  :-/  ;)
Hannah Judes Dad
« Reply #4 on: 03 August 2010, 19:34:24 »
My head or the back of the steering wheel?
« Reply #5 on: 03 August 2010, 19:37:41 »
 ;D  ;D  ;D  ;D
beemerdevil
« Reply #6 on: 03 August 2010, 19:55:44 »
Hi guys
Disconnect the battery, you've got 15 secs from turning theignition off & taking the earth lead from the battery or the alarm will sound.Go & have a drink/smoke/walk round the block  ;)
The wheel is held by a tapered spline. Slacken but don't completely remove the lock nut from the centre of the wheel. If you're lucky, the wheel will come off with a 'judicious' clout from behind using your palms ..... this is why you leave the nut on to preserve your smile  ;)  ;)  ;). If you're not luckyy like this one ...... http://cgi.ebay.co.uk/Laser-GM-Vauxhall-Steering-Wheel-Puller-/160463335121?cmd=ViewItem&pt=UK_Hand_Tools_Equipment&hash=item255c5c2ed1
...but surely the ignition will already be off?? or am i missing something?
« Reply #7 on: 03 August 2010, 23:12:26 »
Airbag ECU is permanently supplied from the battery and also stores charge for some time after disconnection. :y
beemerdevil
« Reply #8 on: 04 August 2010, 12:04:12 »
cheers Kevin....but what I meant was, if I have 15 secs. from switching off ignition to disconnecting battery,  do I slacken off battery lead(s), with engine running, switch off then run round and take off battery leads ??? otherwise alarm will sound?? :-[ am i getting wrong end of stick?? also, how long do i leave it before removing a/bag??  TIA  :y
« Reply #9 on: 04 August 2010, 12:07:26 »
cheers Kevin....but what I meant was, if I have 15 secs. from switching off ignition to disconnecting battery,  do I slacken off battery lead(s), with engine running, switch off then run round and take off battery leads ??? otherwise alarm will sound?? :-[ am i getting wrong end of stick?? also,  ....
Almost  ;). Disconnect within 15 secs of ignition being turned off. Don't run the engine with a slckened earth connection.  :y
I can't say for airbag, some say 10 mins others say and hour or so. No harm in leaving longer.  :y
beemerdevil
« Reply #10 on: 04 August 2010, 16:58:22 »
but I wont have the ignition switched on will I?! - open the bonnet, disconnect battery.  Or do I; loosen battery conns; turn on ignition; turn OFF ignition; run round and take off battery conns.  Yes ?? - sorry guys, but i dont see why I would have the ignition on. run it past me............lol  : ::) ::)
« Reply #11 on: 04 August 2010, 17:01:12 »
 Or do I; loosen battery conns; turn on ignition; turn OFF ignition; run round and take off battery conns.  Yes ?? - ......
Correct!  :y
You've turned the ignition cos that's the sequence.  ;) If you don't disconnect the battery within 15 secs of turning it off then the alarm will sound. .
Bose Addict
« Reply #12 on: 06 August 2010, 17:00:08 »
Wouldn't removing the airbag fuse be easier than battery disconnection?  Or it is still dangerous?
(btw RAC man CHANGED my battery with engine running.  Headlamps were on to 'absorb any surges' he said.  I never had any problems subsequently but  I  wouldn't do it myself!)   :o
« Reply #13 on: 06 August 2010, 17:35:20 »
Did he have spurs on his boots? ::)
