Author Topic: V6 front brake disc noise  (Read 1709 times)
24_Valve
  • Greater London
« on: 05 August 2010, 23:37:22 »
My drivers side front brake disc is making a nasty scraping noise.. sounds like a crushed coke can scraping against the disc. I removed the wheel and slowly rotated the disc itself and the noise is apparant for about 1/3 of each rotation with very slight resistance while noisy.. pads are a little worn but never heard this sort of noise before. No noises when braking & passenger side is fine  :question
Previous: 1996 Omega 2.5i V6 Manual Estate. Pearlescent, Polar Sea Blue. Walnut Trim. A/C & E/S/R. ABS & TC. Heated Seats. 16" Face Lift Alloy's. 225/55 Kuhmo Ecsta KH11 Tyres. NGK BKR5EK Plugs - All Six !
markspark
  • Bolton
Re: V6 front brake disc noise
« Reply #1 on: 05 August 2010, 23:43:33 »
have a look round the rear of the disc the dust guard may be catching
Is there a wobble on the steering wheel when the brakes are pressed whilst driving??
tidla
  • solihull
« Reply #2 on: 05 August 2010, 23:53:56 »
you would be suprised where stones can get! as above check the backplate if all mechanicals are a ok.
24_Valve
  • Greater London
« Reply #3 on: 05 August 2010, 23:56:54 »
no wobble, but will check dust guard  :y could worn disc pads scrape like this  :question never known them to
markspark
  • Bolton
« Reply #4 on: 06 August 2010, 00:01:00 »
yes they would cause a noise like that  metal on metal not good
24_Valve
  • Greater London
« Reply #5 on: 06 August 2010, 00:08:12 »
don't want scored discs so if the dust guard is clear i'll fit new pads. warning from pad sensor hasn't come on & only scrapes through 1/3 of rotation
markspark
  • Bolton
« Reply #6 on: 06 August 2010, 00:34:15 »
sensor may not be working correctly it could have been by passed at some stage in the cars life
24_Valve
  • Greater London
« Reply #7 on: 06 August 2010, 00:36:30 »
fair point  :y
markspark
  • Bolton
« Reply #8 on: 06 August 2010, 00:37:21 »
only 1/3 of rotation is a sign of warped disc thats why i said about wheel wobble whilst braking whilst driving
24_Valve
  • Greater London
« Reply #9 on: 06 August 2010, 00:49:31 »
had crossed my mind, i'll look for uneven wear on the pads. if need be, also replace discs.
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #10 on: 06 August 2010, 05:08:21 »
 :D Its probably a stone lodged between the disk back plate and the disk. Thery can flick off the road and adhere to the backplate from a newly surfaced road.
If there is no wheel wobble and the pads are of a good thickness a stone is the better probablitiy.
5 minutes to check and put yourself at ease.
Wear sensors will not cause this noise!
GudLuk :y
24_Valve
  • Greater London
« Reply #11 on: 07 August 2010, 00:27:59 »
Cheers mate  ;)
