Author Topic: Knocking noise from front offside of vehicle  (Read 1331 times)
willerby
« on: 06 August 2010, 12:47:08 »
Hello I have a knocking noise from the front offside of my 2.2 petrol.When you bounce the car up and down when it is stationary you hear the knocking but it is quite difficult to pin point it.It is loader when the bonnet is open.Any help will be very much appreciated.
Sixstring
  • Lydney, Gloucestershire
Re: Knocking noise from front offside of vehicle
« Reply #1 on: 06 August 2010, 12:55:06 »
Check wishbone and tie rod arm bushes first..............
« Reply #2 on: 06 August 2010, 13:08:20 »
Jack both side and wiggle all the joints, and rock the road wheels at 12 and 6 o'clock for wheel baring play, and 3 and 9 for track rod play, drop links give a high frequency rattle, steering joints and baring can knock over bigger bumps when bad enough. Chesk wishbone bushes are firmly held, and steering idler has no vertical play.
« Last Edit: 06 August 2010, 13:08:52 by chrisgixer »
« Reply #3 on: 06 August 2010, 21:52:19 »
Drop links  ;)
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 07 August 2010, 09:35:44 »
As you said its louder when you open the bonnet,i thought maybe suspension top mounts maybe. :-/
willerby
« Reply #5 on: 07 August 2010, 16:16:58 »
Its the drop link. Thanks for the advice. :y
Alldi
  • Hampshire
« Reply #6 on: 07 August 2010, 21:42:31 »
I had a loud noise coming from my front suspension, I was convinced it was the strut top mounts such was the racket. Local garage said it was the drop links but I didn't believe it but changed them anyway and it cured the noise completely. To say I was amazed would be an understatement. ;D
« Reply #7 on: 08 August 2010, 02:39:50 »
No probs mate - glad its cured :y
Page created in 0.024 seconds with 16 queries.
