Author Topic: Front Brakes discs & Pads  (Read 1644 times)
Goonybird
  • Northampton
  • Shouldn't have gone to Specsavers
« on: 08 August 2010, 11:27:29 »
Just done front pads and disc this morning to find the discs are the earlier smaller diameter  :-?
So the pads over hang by 5mm.
1) is this a problem
2) do I need the larger discs or is there a slimmer pad I can fit?
Fortunately I only need the car tomorrow for a 40 mile round trip before doing anything.
So if discs need to be changed may have a cheap pair of newish discs for pre 98 miggies.
Stef
Have owned: Opel Manta A 1900 Auto Berlinetta, Opel Manta B 2.0 Auto Berlinetta, Vx Royale Coupe 2.8 Auto, various non Vx, Skoda Superb 130tdi currently Omega 2.5CDX - now Octavia vRS WRC
Re: Front Brakes discs & Pads
« Reply #1 on: 08 August 2010, 11:29:18 »
All Omega brake discs (except very early 2.0's) all use 296mm discs, did you get them from a dealer?
« Last Edit: 08 August 2010, 11:29:31 by tunnie »
Goonybird
  • Northampton
« Reply #2 on: 08 August 2010, 13:39:48 »
Off the 'bay as NOS. box labelled as 3.0 omega and model numbers checked as correct on manufacturers website. Contents appear to be correct to box.
Paid under £30 inc postage.
Just need to get a 296mm set.
« Reply #3 on: 08 August 2010, 13:53:08 »
did the eGay advert specify the size in mm?
« Reply #4 on: 08 August 2010, 14:19:13 »
Wouldn't even consider driving it in that condition mate.
Pattern disks no good on Omegas - you'll get brake judder in a short while - go for genuine Vx disk and pad set :y
Goonybird
  • Northampton
« Reply #5 on: 08 August 2010, 16:10:05 »
Just checked again, must be the hot weather!
Omega 3.0 must mean Carlton 3.0 - as in Omega A
live and learn  ;D
« Reply #6 on: 08 August 2010, 16:42:23 »
live and learn  ;D
Carlton front disks were 258mm dia
Early Omega 2 lit were 286 mm dia
Believe Carlton 3 Lit  disks were 280mm dia with the Carlton 3 lit 24 valve being 296 mm dia.
Yours should be 296mm dia - the 5mm overhang suggests you got early Omega 2 Lit disks.
