Author Topic: Front brake picture?  (Read 1072 times)
GaryBC
  • Egham, Surrey
« on: 09 August 2010, 11:02:22 »
Somewhere on this site is a really good photo of the front brake assembly.
Anyone know where it is?
Cheers,
Gaz
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: Front brake picture?
« Reply #1 on: 09 August 2010, 11:55:36 »
Cheers,
Gaz
That's a bit of a question but you're welcome to look at these if it helps.  It's a 2000 3.0 Elite
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
GaryBC
  • Egham, Surrey
« Reply #2 on: 09 August 2010, 12:31:06 »
Cheers,
Gaz
Yeah!! Sorry I can't be more specific! They're a good set of pics but they don't contain the one I was thinking of.
What I'm after is the correct routing for the wear sensor wire. I have a constant pad wear warning and the last MoT tester told me it was the way the wire is routed that is the problem.
Liam
« Reply #3 on: 09 August 2010, 12:35:22 »
Are you sure you have sensors at all?
Chris_H
  • E London/Essex UK
« Reply #4 on: 09 August 2010, 12:48:34 »
Cheers,
Gaz
The first one on my link shows the route clearly.
If you have intermittent warning the it's too late to change the route for that sensor/cable - you already have a break.
GaryBC
  • Egham, Surrey
« Reply #5 on: 09 August 2010, 12:56:55 »
Cheers,
Gaz
I should have looked closer!! I take your point - if I fitted it wrong in the first place it is already broken!! I'll get a new one and follow the routing in your pic.
Thanks for your patience!
Gaz
Chris_H
  • E London/Essex UK
« Reply #6 on: 09 August 2010, 14:11:23 »
You should be able to buzz the existing one with a multimeter if you have one, to check for a cable-break.
If you put a new one on, try to get someone to turn the wheel from lock-to lock while you watch with the wheel off, to ensure that the wire doesn't get tight at any point.  It's possible to move the slack around so it needs to be distributed right.  Make sure your hands are out of the way and that you have more than a jack holding the car up though.
