Author Topic: Barrel broke num 2, HELP !!  (Read 968 times)
omegod
  • liverpool
    • 2017 Seat Ateca
« on: 10 August 2010, 19:18:04 »
Ok so I found my barrel was a bit knackered but went to put it back in this morning only for the little sprund tab to split, got another barrel and key today just tried to fit it and the tw*t has cracked in the same frigging place.
I cant see how this is happening as the steering lock is out of the way and tried the key in every position but it wouldn't go the last bit in.
Anyhow i'm stuffed now unless anyone nearby has a spare or a breaker....anyone???
omegod
  • liverpool
    • 2017 Seat Ateca
Re: Barrel broke num 2, HELP !!
« Reply #1 on: 10 August 2010, 20:14:43 »
OK knobhead admission time, I didn't have the black cap end set to the right position after fiddling this morning but got the new one in with half the remaining clip so it will start and steer , could still do with an undamaged barrel though!!
robbo299
  • luton, beds
« Reply #2 on: 10 August 2010, 20:39:29 »
Is this the part you need?
I have a replacement barrell and key on its way to me at this moment. If it all fits ok your more than welcome to my old barrell. The mechanism in mine is knackered but if you want just the casing your more than welcome to it.  :y
