Author Topic: Anyone run BMW wheels on their Omega?  (Read 3017 times)
AlistairK
« on: 06 August 2010, 18:18:27 »
Question as per title really.
I was thinking of upgrading to 18" wheels and BMWs have the same 120mm stud pattern right?  So I assume there's no real reason I can't grab some used 18s off a BMW, bolt them on and cruise away...
Anyone done this?  Any issues with offset or whatever?
Re: Anyone run BMW wheels on their Omega?
« Reply #1 on: 06 August 2010, 18:32:40 »
Thought Omega were 110mm PCD
There was a thread regarding 112mm PCD wheels not fitting the other day, so BMW ones dont stand a chance.  :-/
« Last Edit: 06 August 2010, 18:32:54 by skruntie »
beemerdevil
« Reply #2 on: 06 August 2010, 18:39:20 »
Omegas are 5 x 110  :y
AlistairK
« Reply #3 on: 06 August 2010, 19:35:49 »
OK thats cleared that little misunderstanding up then.
 :-[ :-X
Cheers.
I'll keep an eye out if any Omega standard wheels take my fancy then.  MV6 have a nice 5 spoke IIRC?  I'm not much taken by the CDX alloys
I_want_an_Omega
« Reply #4 on: 06 August 2010, 20:22:07 »
MV6 wheels buckle very easily but look nice.
pedroMV6
  • York
  • Der Metzgermeister
« Reply #5 on: 06 August 2010, 22:32:20 »
Pre FL ones might, the FL ones certainly don't! ;)
To help with the original question, you can get wheel adaptors from DTMotorsport in Essex.
Got some on my Carlton, as the AZEVs are 5 x 112. :y
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #6 on: 06 August 2010, 23:09:12 »
No offence mate, but why would you want to put BMW wheels on your Omega??
tidla
  • solihull
« Reply #7 on: 06 August 2010, 23:18:03 »
if the pattern suits....
« Reply #8 on: 06 August 2010, 23:20:51 »
Why indeed....?
tidla
  • solihull
« Reply #9 on: 06 August 2010, 23:31:21 »
looking thru the gallery there are many imaginitive ideas that i and others may not of thought of, newbie or not.
some get a thumbs up, others not so.
if you dont try, you will never know..
holtender
  • Suffolk
    • 2.5 CDX Facelift
« Reply #10 on: 07 August 2010, 02:04:06 »
I'm a traditionalist when it comes to cars, changing anything that is not in the original Spec just de-values a car in my opinion.
I don't know who designed the Omega, likely many different people, but to me they really got it right and it works 100% for me.
But I guess others  like to tamper with their Omegas and thats fine also..
« Reply #11 on: 07 August 2010, 02:08:26 »
Indeed, but my personal concern is the BMW association that may go with it. Each to their own though as you so rightly imply. :y
AlistairK
« Reply #12 on: 07 August 2010, 08:23:27 »
reason:  BMW have some nice styled roadwheels on some of their later model cars.  I don't much like the wheels on the CDX.  They aren't offensive or anything, there are just much nicer looking wheels out there.  Plus there's a place by work sells 2nd hand alloys and they have tons of BMW ones in...
As for devaluing the car
1. the stock wheels can always go back on at resale time
2. a ten year old Vauxhall isn't exactly an "investment"...  Its one step up from "disposable".
I haven't seen the gallery, so I shall go have a look and see what else people have got on theirs.
I would rather avoid having to run adaptors.
I'm not prepared to spend the money to buy new alloys special ordered in the correct pattern, so its about what I can pick up second hand.
SJKOO01
« Reply #13 on: 07 August 2010, 12:22:41 »
Some of the Saab's have the same stud pattern too  :y
But what ever other wheels that you can find with the same stud pattern, or using something near and using adaptor bolts if it's 1-2mm out.  Don't forget to take into account the offset measurement to, as you need to get near the same as per original spec wheels, so you don't catch the wheel arch or parts of the suspension.
Hope that helps ?  :y
« Last Edit: 07 August 2010, 12:23:03 by SJKOO01 »
« Reply #14 on: 07 August 2010, 18:31:49 »
unfortunately 5x110 wheel alternatives not too many like 5x120..
metal machining shops may help imo..I did a bit research before and they can prepare something instead..
then you can use 5x120..
but cant estimate the price for there..
ps also there are pcd adapters..
« Last Edit: 07 August 2010, 18:36:33 by cem_devecioglu »
