Author Topic: brake pads  (Read 1608 times)
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
brake pads
« on: 10 August 2010, 23:00:24 »
the brakes on my car have started to sort of screech a little, and when im going fast ( around 100 - 110 miles ) and I press the brake, they feel quite hard, and the effect isnt quite strong either, plus they also vibrate a little ( the brakes, not the tyres )
Im guessing its the brake pads, but i dont know which ones, i mean front or rear ??
Secondly how do i check the brake fluid, because I think its also low ??
tidla
  • solihull
Re: brake pads
« Reply #1 on: 10 August 2010, 23:04:02 »
heavy braking will cook the brake pad material (turning it ginger) and start to squeal. the vibration is corroded/ warped brake discs.
i think an upgrade is necessary if those kind of speeds are a regular!
replace the brake fluid as well is probably steam..
« Last Edit: 10 August 2010, 23:05:09 by tapper888 »
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: brake pads
« Reply #2 on: 10 August 2010, 23:05:29 »
Search 'eBay.co.uk'.  Look for a 'Haynes Manual' for the Vauxhall Omega.  Make sure the seller will post worldwide.
For about £35, you'll have the equivalent of a Holy Book of your car when it comes to general maintenance.  :y
« Last Edit: 10 August 2010, 23:09:39 by Broomies_Mate »
tidla
  • solihull
Re: brake pads
« Reply #3 on: 10 August 2010, 23:07:50 »
Search 'eBay.co.uk'.  Look for a 'Haynes Manual' for the Vauxhall Omega.  Make sure the seller will post nationwide.
a bit further a field. :y
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: brake pads
« Reply #4 on: 10 August 2010, 23:08:53 »
HAHA.  I meant Worldwide.  I am so stupid sometimes!
EDIT: Post edited.
« Last Edit: 10 August 2010, 23:09:59 by Broomies_Mate »
Fazeel
  • Bahrain
Re: brake pads
« Reply #5 on: 10 August 2010, 23:15:09 »
so the vibration is brake discs, hmmm,
Cant I do anything about that ??
apart from replacing them, cause replacement would be a bit expensive, but im sure going to replace the pads.
And can someone tell me where the check the brake since i hardly ever open the bonnet, so i dont know where it is, plus its not labeled or anything, and also tell me how much it should be ??
tidla
  • solihull
Re: brake pads
« Reply #6 on: 10 August 2010, 23:15:18 »
what is the score with the roads over there?
Fazeel
  • Bahrain
Re: brake pads
« Reply #7 on: 10 August 2010, 23:18:54 »
im assuming you are asking the speed limit, well on highways its 85,
But i drive fast :P
Its cause im a teenager and this is the age to do it !! ;)
tidla
  • solihull
Re: brake pads
« Reply #8 on: 10 August 2010, 23:21:24 »
seen top gear do a few road tests..
Fazeel
  • Bahrain
Re: brake pads
« Reply #9 on: 10 August 2010, 23:23:50 »
hahahaha top gear can do anything !!
Those guys are awesome !!
Broomies Mate
  • Bristol, UK
    • Stuff!
Re: brake pads
« Reply #10 on: 10 August 2010, 23:24:17 »
But i drive fast :P
Generally speaking, it's also the age where you are inexperienced, and cause death and devastation.
I am certainly not preaching, as I did the same, and to an extent (much lesser extent) still stretch the old-girls legs, when clear and 'safe' (safer) to do so....
Just be careful!
Fazeel
  • Bahrain
Re: brake pads
« Reply #11 on: 10 August 2010, 23:27:28 »
yeah I know, my parents tell me the same all the time,
But i dunno, everything seems to provoke me once im on the road :P
Its just soo tempting and thrilling !!
