Author Topic: Intermittent Fault  (Read 1905 times)
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Intermittent Fault
« on: 09 August 2010, 18:39:06 »
My car today has  cut out several times and will not fire unless left for maybe half an hour and then it  starts this has happened  5 times any idea what problem is?
tidla
  • solihull
Re: Intermittent Fault
« Reply #1 on: 09 August 2010, 18:44:22 »
9/10 times crank sensor.
someone will be along soon with fault code detail.
« Reply #2 on: 09 August 2010, 18:47:07 »
Do the "Pedal Trick" as found in the maintenance section... You'll get the code for a Crankshaft Sensor ;)
Replace ASAP before it gives up altogether and leaves you stranded :y
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #3 on: 09 August 2010, 19:09:09 »
...not always you won't..
but its 99% CPS causing the issue, and easy to replace anyway
« Reply #4 on: 09 August 2010, 19:16:06 »
True... But I'd put money on it ;) ;)
Only £1 though :D :D
harpersimon
  • Marlow, Bucks
« Reply #5 on: 09 August 2010, 22:06:54 »
LOL!! Oh for sure it will probably, I am just saying that if not, then this is still probably Crank sensor, and should be replaced for the sake of what it fixes in this instance
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #6 on: 10 August 2010, 12:28:16 »
You were correct Crank sensor was the problem
harpersimon
  • Marlow, Bucks
« Reply #7 on: 10 August 2010, 14:52:43 »
Good stuff!
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #8 on: 11 August 2010, 18:48:36 »
Sorted the problem it was the crankshaft sensor .For some reason the car is much more responsive after fitting new sensor from a sedate car to a racing car. does this mean that my timing or fuel injection is timing better. interesting to see how the fuel consumption goes.
