Author Topic: dirty interior :(  (Read 1342 times)
Fazeel
  • Bahrain
    • Opel Omega 3.2 V6 2002
dirty interior :(
« on: 09 August 2010, 01:14:49 »
ok, i dont know what the previous owner for my car did, but there's this sticky sort of dirt stuck all around the gear lever, i mean on all that black place and even under the handbrake, oh and also on the the buttons surrounding the stereo.
Its very irritating because its very sticky !!
plus it looks very ugly !!
Ive tried a little to remove it, but nothing works, except for if I start scratching it with my finger nails, lol
Actually I read lemon juice removes dirt somewhere but that didnt work, apart from that havent tried using chemicals for I am scared it might remove the paint or something.
Any suggestions on what should I do ??
I wish I could upload some pictures of it, but i dont know how to :(
Re: dirty interior :(
« Reply #1 on: 09 August 2010, 01:27:01 »
Lemon juice is worth a try, put some on a cloth to make it damp and try wiping obey the surface to clean it a few times.
« Reply #2 on: 09 August 2010, 01:28:16 »
Might be that some one has spilt a can of coke, as it dries that gets sticky
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #3 on: 09 August 2010, 09:57:47 »
you'll probably find this isn't dirt, its the rubber coating that VX decided to coat the interior with. looks like a greasey horrible finish as soon as its worn to any degree.
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 09 August 2010, 10:17:48 »
There is only one thing that will work with this (it can be dirt not a rubber coating).
Use standard home window cleaner but be very careful cause it is quite agressive.
Clean with it then after with  rag dipped in water to remove the cleaning agent.
Repeat if neccessary.
Fazeel
  • Bahrain
« Reply #5 on: 09 August 2010, 11:49:55 »
should i use alcohol or spirit ??
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 09 August 2010, 12:01:00 »
Standard window cleaner shampoo in spray bottle (ajax, vanish, brill or whatever manufacturer).
shane1000
  • derby
  • studied nothing for 35yrs so now an expert on it
« Reply #7 on: 11 August 2010, 20:55:24 »
i've found a little vinegar in warm water with a soft toothbrush is ideal for the nooks and crannies ...it always comes up a treat
Page created in 0.037 seconds with 16 queries.
