Author Topic: coolant display  (Read 823 times)
davey w
  • cheshire
coolant display
« on: 11 August 2010, 20:57:57 »
As above this is staying on on the lcd display i have checked the level and its fine,but some 1 told me that it could be something to do with a sensor in the bottle?is this expensive to replace/common fault?i am a novice on this car so any help would be appreciated cheers. :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: coolant display
« Reply #1 on: 11 August 2010, 20:59:57 »
Sounds like someone has told you right there mate :y
New bottle with the sensor are about £30 from Vauxhall :y
davey w
  • cheshire
Re: coolant display
« Reply #2 on: 11 August 2010, 21:04:22 »
Are they hard to fit do you know,as i`m not realy any good at doing any kind of mechanical work unless i have a step by step guide.
Re: coolant display
« Reply #3 on: 11 August 2010, 21:06:09 »
Before you go off & spend your hard earned, lever off the metal clip holding the expansion bottle to the inner wing, push the bottle backabout 1 inch until it is free. Carefully lift it & check that the sensor plug is still tightly fitted. If it is, i've just wasted your time, if it isn't you've just saved some dosh! Simples  ;D ;) :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: coolant display
« Reply #4 on: 11 August 2010, 21:07:46 »
No it is very easy mate :y
Page created in 0.03 seconds with 16 queries.
