Author Topic: Under car heat  (Read 2040 times)
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
Under car heat
« on: 11 August 2010, 22:54:30 »
Hi all...
I have noticed that whenever I have been out in the Omega, when I switch off and get out, there is a massive amount of heat comes out from the exhaust and almost burns your ankles.
Swmbo has also commented about it on the passenger side.
Never noticed it on any other car. Is this normal with Omega's or is there a problem !!!!!
TIA
Tony C
Re: Under car heat
« Reply #1 on: 11 August 2010, 22:56:40 »
Hi all...
TIA
Tony C
Normal I think, not sure about the burning part though. Notice it more lately as I'm wearing shorts to work in the warm weather.
Re: Under car heat
« Reply #2 on: 11 August 2010, 22:56:48 »
.... Is this normal with Omega's  ......
Pretty much so, it's not a little engine & the heat has to go somewhere. Wait till you turn the engine off after a long-ish run on a hot day ........ then there's loads of heat.  :y :y
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Under car heat
« Reply #3 on: 11 August 2010, 23:06:22 »
Have done that Andy, that is what was worrying me....the amount of heat that shoots out from under is enough to cook a BBQ.
Did not want to see my baby go up in smoke  :(
But if you fellas say its normal, thats a weight off my mind.  :y
megaomega123
Re: Under car heat
« Reply #4 on: 11 August 2010, 23:32:15 »
Completely normal. I was camping recently and it was a cool night. Had the car running for electric and the better half warmed herself next to the car  :y
Great little heater.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Under car heat
« Reply #5 on: 11 August 2010, 23:34:44 »
the cooling fans dont half blow it out around the front doors. normal. :y
zvi
  • IL
Re: Under car heat
« Reply #6 on: 11 August 2010, 23:35:59 »
That's because the main fan goes on a bit pushing the heat to your legs
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
Re: Under car heat
« Reply #7 on: 11 August 2010, 23:51:16 »
Great stuff fellas  :y
Strange how it has never been noticed on any of the other cars I have owned. Must be the underbody shape or something ??
At least it will stop swmbo giving me grief every time she gets out of the car >:(
The Red Baron
Re: Under car heat
« Reply #8 on: 11 August 2010, 23:58:16 »
the cooling fans stay on to cool down after youve switched off, loads of hot air so to speak. & no im not on about the wife :D
Re: Under car heat
« Reply #9 on: 12 August 2010, 00:33:43 »
Plus the cats are directly inboard of the front doors.... And I'd keep her guessing if I where you, or she'll find something else to talk about... ::)
The Red Baron
Re: Under car heat
« Reply #10 on: 12 August 2010, 00:49:21 »
mines full of it though. :D
Sixstring
  • Lydney, Gloucestershire
Re: Under car heat
« Reply #11 on: 12 August 2010, 08:59:53 »
mines full of it though[/highlight]. :D
Oooh! you're brave..................
The Red Baron
Re: Under car heat
« Reply #12 on: 12 August 2010, 14:25:57 »
only speaking the truth mike :D ;D
2woody
  • Northumberland
Re: Under car heat
« Reply #13 on: 12 August 2010, 15:55:20 »
Omega B runs quite hot by design. It, therefore, needs a fairly advanced cooling system with amongst other things a two-speed fan.
the first speed cuts in relatively early, resulting in it actually running most times that you pull up to a halt. Most other cars don't do this.
