Author Topic: mpg computer thing  (Read 3786 times)
elite col
mpg computer thing
« on: 08 August 2010, 19:37:48 »
is it normal to show brake test everytime you start car followed by coolant level before you get onto what you want to look at ?
just both my vectras were the same too
leedsleedsleeds
Re: mpg computer thing
« Reply #1 on: 08 August 2010, 19:44:28 »
my brake test always come on,wasnt till in for repaire for injector seals that coolant level now always comes on! annoying but she still goes lol
elite col
« Reply #2 on: 08 August 2010, 19:47:53 »
yeah its just this is the 3rd vauxhall ive had that does the same 2 things,everytime
wondering if it was normal
dragonlord
  • luton
« Reply #3 on: 08 August 2010, 19:51:47 »
break test is normal to you put your foot on break
coolent aint unless coolent in low or sensors/wireing playing up
« Reply #4 on: 08 August 2010, 20:34:25 »
BRAKELIGHT TEST is normal - it can't test brake light bulbs until you have put foot on brake.
BRAKE PAD is not.
COOLANT LEVEL is not.
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #5 on: 08 August 2010, 22:38:17 »
As mentioned, Brake Test is normal and will disappear when you press the brake pedal (unless you have a brakelight out).
Coolant Level:  If you have sufficient coolant, the sensor, which is a float in the expansion bottle is probably clogged with lime, or other contaminants.  Remove the expansion bottle (nice and easy) and wash it thoroughly with clean water and a detergent.  If it is limescale, use the stuff you put in kettles to get rid of it.
Failing that, I believe a new expansion bottle is only £30 ish from Vx.
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #6 on: 10 August 2010, 16:37:49 »
I get Brake Pad come up - but having checked the pads are all fine wear wise, am assuming one of the sensors on them.. isnt.
« Reply #7 on: 10 August 2010, 18:36:00 »
yup, the sensor is a seperate item that clips into pad
harpersimon
  • Marlow, Bucks
« Reply #8 on: 11 August 2010, 12:49:09 »
yeah its there, and clipped in  - but still get the message.
Is there one both sides?
are there sensors on the rear?
can you buy new sensors seperately? or do they come only with VX pads or something
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #9 on: 11 August 2010, 15:41:26 »
1. Is there one both sides?
2. are there sensors on the rear?
3. can you buy new sensors seperately?
1. Yes, at least there is on my Omega, although I've seen Vectra's with sensors on one side only.
2. No.
3. Yes.
« Reply #10 on: 11 August 2010, 15:43:58 »
can you buy new sensors seperately?  ....
ALL pads come with separate sensors.
harpersimon
  • Marlow, Bucks
« Reply #11 on: 11 August 2010, 22:04:43 »
no they don't - I have purchased pads without sensors, hence wondering if you can get the sensors as a seperate purchase (unless thats what you meant) :y
« Reply #12 on: 11 August 2010, 22:10:10 »
Thats how i read it, you have to buy the sensors separately, if you buy a set of brake pads or dics and pad set, sensors are always an extra
harpersimon
  • Marlow, Bucks
« Reply #13 on: 11 August 2010, 22:13:32 »
Cool thanks - so for the sake of clarity, the meaning was "No pads come with sensors, you have to buy them seperately"
I'll get down my friendly dealer and get some - see if that resolves my Check message
« Reply #14 on: 11 August 2010, 22:21:18 »
before 2001, 1 sensor each side.
