Author Topic: Dumped oil won't start  (Read 2234 times)
Bumbazor
  • Worksop
« on: 13 August 2010, 15:47:15 »
Help!
Coming back from work my oil light came on so I pulled over. Oil everywhere around the engine nearside, near the filter, and most of it on the ground. Dipstick shows no mark at all. Drove a bit further to another layby but it stalled just as I approached. Now it won't start. Am waiting for recovery but in the meantime, any ideas?
Rob-Mitton
  • Sheffield, South Yorkshire
Re: Dumped oil won't start
« Reply #1 on: 13 August 2010, 15:49:23 »
Not sure on the reason for the oil loss, but if you drove the car with no oil in, thats not good and could be a large bill :(
Rob
« Reply #2 on: 13 August 2010, 15:50:24 »
Help!
Afraid to say that if you drove on with no oil then you've probably knackered the engine :'( :'(
Bumbazor
  • Worksop
« Reply #3 on: 13 August 2010, 15:53:35 »
It was about half a mile I drove, is that still enough to knacker it?
What have I probably damaged?
Rob-Mitton
« Reply #4 on: 13 August 2010, 15:57:40 »
Any distance without oil is not gonna do it any good. half a mile if it dumpped it all that fast could be a really bad thing. :(
Rob
« Reply #5 on: 13 August 2010, 16:06:14 »
I can't really believe you've done that mate? :o IR it didn't stall, more likely to have seized up! Don't attempt to turn it over anymore until you've at least sorted the leak & topped it up again! :'(
Bumbazor
  • Worksop
« Reply #6 on: 13 August 2010, 16:06:32 »
So what might be damaged in the engine?
Rob-Mitton
« Reply #7 on: 13 August 2010, 16:09:03 »
Bearings don't take well to no lubrication matey :(
Rob
« Reply #8 on: 13 August 2010, 16:51:38 »
Yep. If the oil pressure light comes on you need to cut the engine immediately, and even then you might not avoid damage. Half a mile will have wrecked the internals, I'm sorry to say. :'(
« Reply #9 on: 13 August 2010, 17:03:18 »
A better question is what wouldn't be damaged inside the engine.. and the answer to that is.. not a lot!
